Sponsored by: Real Truck
Bent frame
Old Apr 25, 2016 | 09:43 PM
IHateCommieCars's Avatar
IHateCommieCars
Bent frame
Bought a salvage F250 from blurry pics and the frame is bent - just the front end where the bumper attaches. It's pushed a good couple of inches towards the passenger's side. Is that easy to straighten or would I cut it off and weld a new one on? I got a parts truck with all the parts I'll need. Wonder if a frame shop would charge me less to straighten it than a welding shop with charge to cut the old one off, then the replacement one off the parts truck, then weld it to the new truck.
Old Apr 25, 2016 | 09:54 PM
dkf's Avatar
dkf
Would be better off having a frame shop do it even if it costs more. The frame shop can make sure everything is within spec.
Old Apr 25, 2016 | 10:39 PM
cyncwby's Avatar
cyncwby
I will second that, it may be bent in places you can't see, the frame jig will tell just how straight it is.
Old Apr 25, 2016 | 11:07 PM
machmedic's Avatar
machmedic
I agree on take it to a frame shop also. Check your bed to cab gap also, if its uneven frame is bent further back. Had that type of repair done on a '97 F-250, turned out great.
Old Apr 26, 2016 | 07:52 AM
Chuck's First Ford's Avatar
Chuck's First Ford
a bent frame can be bent and you could NEVER see it with EYES...
also a small kink in the frame could prevent you from ever getting the front end aligned correctly.
or a Truck that Dog Tracks...
a Frame Shop.. No question. or part out the truck.
sukonater
1997 - 2003 F150
Apr 14, 2009 09:59 AM
triumph_rick
Oct 17, 2006 11:46 PM
CLWunschel
Sep 22, 2003 01:34 PM
DJ Rosa
May 28, 2003 10:01 AM
