Dorman up pipes
They MAY be some sort of VERY low grade magnetic stainless, given how little they have rusted so far. But, if that is is the case, it would be an even lower grade then certain oem exhaust, such as older GM pipes, so they(Dorman) probably wouldn't want to claim/market it as a stainless.
Mine do show some very light surface rusting (and hence can't be true stainless), at spots where the paint was scratched off, or got washed off from oil leaks,etc.. But, as I said, its very minor and nothing beyond surface blemishes. With this little bit, after 2 years of NJ roads ( winters/salt), I'm confident they have many years left in them. Particularly since I will re-paint them when everything comes out for my drive train transplant this summer.
The Dorman pipes are indeed stainless, a similar grade to the OE exhaust system. Collector is cast iron, but pipes are ss. I believe this for several reasons; first, it says so on their website. Also I tested the pipes that came with my kit. I did not cut it up and throw it on the spectrometer to get a reading of all the constituent elements, but I did the ghetto tests; a magnet did not stick, swabbed with acid it did not stain, and very few sparks flew when I hit it with the grinding wheel. Not conclusive proof like a real chemistry to show percentage of alloys, but these are DIY ways to characterize stainless vs mild steel.
Almost forgot; due to the confusion back then I contacted Dorman and got the response below on 11/19/15 before purchasing:
The pipes are made of 409 stainless
Thank you
Jim S**********
Dorman Products
Asst Product Manager/Tech Services
215-712-**** Desk
215-712-**** Fax
Or Toll Free
1-800-868-5777 ext.****
So that's why I think they are stainless. Not the quality of workmanship of the IH version fer shure, but the materials are comparable.
To OP: the wicked wheel is obsolete compared to the newer billet jobbies. Much lighter so they spool faster, plus make more boost. Great time to upgrade! Riff Raff, Dieselsite, SP Turbo come to mind.
Another difference between these and IH / RR (and even Dorman) up-pipes might be the length of the bellows, which would affect amount of expansion allowed. IDK really, just a supposition.
These are supposed to be true polished stainless up pipes.
Ford Super Duty 1999-2003 7.3L Powerstroke Diesel Stainless Turbo Up Y Pipe Kit | eBay
Careful though, a power hungry blowhard moderator might get all butt-hurt and slap you for daring to post a link to a product that isn't sold by one of "our" almighty sponsors........
Thank you
Jim S**********
Dorman Products
215-712-**** Desk
215-712-**** Fax
Or Toll Free
I am also pretty sure my magnet stuck to the pipes. Most OEM grade stainless exhaust I have encountered is magnetic, being a lower grade stainless ( 409 I think?) It seems rather odd Dorman would use a non-magnetic high end stainless(304/316?) when even the oem's don't.
Either way, the Dormans are a good value for the money, and probably the "best" choice for most people ( unless you plan to build an amphibious ocean going SuperDuty).
Then there are the precipitation hardening stainless steels like 15-5, 17-4.
There...rant over.
As for the exhaust outlet, aren't they the same? I know the VAN turbo has a different turbine housing/outlet, but I'm fairly certain the E99 and 99.5+ TRUCK turbos use the same exhaust side/turbine. Only the compressor side is "smaller". Therefor, you should still be able to use the outlet adapter I mentioned. Or am I missing something?
If you need a whole E99 turbo, I have a really clean complete one ( with pedestal) I'm trying to find a new home for. PM me if you want.
There...rant over.
Here's how I see it. 1.) If it rusts, AT ALL, its not "really" stainless. 2.)If a magnet sticks to it, its not "really" stainless.
1.) is for practical considerations. If I am looking for something "stainless" its probably because my main concern is that it doesn't rust/corrode, and stays shiny. So, if it doesn't meet that criteria, its not "stainless" in my mind, as well as probably the mind of many other consumers.
2.) From a scrap perspective, if its magnetic, its junk. In order for a metal to be classed/graded as "stainless", and paid for at a higher price per LB, then it MUST be non-magnetic. If the magnet sticks, its worth no more then your old bed frame or washing machine, and gets tossed in the same pile.
While I realize these criteria aren't scientifically "correct", that is my perspective, from a practical day-to-day point of view.
