Dorman up pipes
I tapped the driver side manifold 10 years ago when first got the truck and installed the gauges.
Any advice on things to look for or replace?
Mods include..
Wicked wheel
6.0 IC
Air raid intake
6.0 26 plate trans cooler
55psi fuel spring
Banks big head
Full 4" magna flow exh
TonyWildman tuned TS chip
EGT-trans-boost guage on the piller
Zoodad mod
Foil delete
AIH delete
Also, I rebuilt the turbo about 3 years ago!! But I bought the 4 viton o-rings for the turbo and pedestal.. As well as the RiffRaff reinforcing rings and boots, with new T-bolts to attach them.. On the fence about the FRX... I know I should do it but I've spent so much on the truck lately. New tires, brakes, and all new CAC boots from RR, For the 6.0 IC.... The wife is not happy, might have to wait a couple weeks😀
have you installed the pipes? i need these bad. bought a 350k mile 1 owner truck that has been neglected besides oil changes. long overdue for many things.
i need up pipes, im assuming the turbo is dusted by the looks of the impeller, cant see obvious EBPV oil leaks but engine was DIRTY when i bought it.
i found dormans on amazon for $130 shipped. dont know who to trust for ebpv delete parts. seems like many of these diesel sites jack up prices.
id like some info on who to trust and a who has good prices. i want to do as much as i can while i have it out. rather not take the trans out.
Hit up RiffRaff and ask for Clay, they should be able to steer you good, they are also well priced on 99% what they carry
As for the other end, the only thing I would soak/worry about is the actual collector to turbo connection. You'll probably have to persuade them apart with some hammer/chisel tapping. The pipes into the collector may just fall apart. If not, again, don't bother with the bolts. Just cut the pipes at a convenient location. Its all junk anyway.
"blank" pedestal ROTOMASTER A1382205N $86.79
hi-flow outlet ( ebpv delete) ROTOMASTER A1383801N $62.89
No need to waste money on Garrett branded parts at inflated prices. Given that you are doing a delete, these parts have no moving parts. In other words, not much to screw up or get wrong. I used these with no problem. They have been on my truck for 2 + years with no issues.
Same with the up-pipes. the Dormans are an excellent choice. Great price. No need to waste money on overpriced International ones, for more then 3 times the cost. Yeah sure, the Internationals are stainless, but the Dormans are sufficiently sturdy for most people. Especially if you give them a good hi-temp paint job prior to install.
Pipes on Dormans are also stainless, fwiw.
This has been debated more then once. They are not stainless. Dorman themselves ( tech line) have said they are not. Dorman says the collector is cast iron and the pipes are mild steel. They are very heavy gauge/wall thickness though.
They MAY be some sort of VERY low grade magnetic stainless, given how little they have rusted so far. But, if that is is the case, it would be an even lower grade then certain oem exhaust, such as older GM pipes, so they(Dorman) probably wouldn't want to claim/market it as a stainless.
Mine do show some very light surface rusting (and hence can't be true stainless), at spots where the paint was scratched off, or got washed off from oil leaks,etc.. But, as I said, its very minor and nothing beyond surface blemishes. With this little bit, after 2 years of NJ roads ( winters/salt), I'm confident they have many years left in them. Particularly since I will re-paint them when everything comes out for my drive train transplant this summer.
These are supposed to be true polished stainless up pipes.
Ford Super Duty 1999-2003 7.3L Powerstroke Diesel Stainless Turbo Up Y Pipe Kit | eBay
