While driving home last night my truck started to overheat, the temp jumped from where its been running at lately (around 210) to 240, I stopped and took it easy getting home. This morning I sprayed down the radiator to clean out any mud that may have gotten in it from field work at the office (its always going through some pretty deep stuff). It ran fine for about an hour then it started to over heat again, I got it home and did a complete radiator flush and then did a test drive. It still overheated so I decided to try something, I released the pressure in the system by unscrewing the cap partially and drove it around again, this time it didn't overheat, put the cap back on and the temp jumped right back up to 240. Any ideas??? Tomorrow I plan on calling my friend that works for international to see if he has any ideas.
since you are new, we need to get you up to 20 posts so you can send & receive messages. You're about 1/4 of the way there.
It would be helpful to know about your setup. So take a bunch of posts to give some additional info about your setup:
year
miles
EGR still installed or an EGR delete?
was the oil cooler ever changed?
what type of coolant?
stock injectors?
stock programming or using a tuner?
Stock head studs?
Do you have the electrical connector to your EGR plugged in?
If the wire is unplugged (regardless of whether you have an EGR delete or not) can mess with the PCM's ability to control the FAN.
Your FAN should sound like a JET engine once the coolant temps get out of normal range, so having to look at the FAN to see it's turning (while idling in your driveway) does NOT provide the key piece of info.
You CAN monitor your FAN speed via ODB, which would be very important, if it reads 2000 RPM but you don't hear it - you have a fan control problem... Either the EGR valve signal is not reaching the PCM or the wire is chaffed where it runs over the fan blade...
