Need Help Overheating
Old Apr 25, 2016 | 08:28 AM
mfiveaa's Avatar
mfiveaa
It has 149533 miles, had 146000 when I bought it a month and a half ago
Old Apr 25, 2016 | 08:29 AM
mfiveaa's Avatar
mfiveaa
Stock EGR with the electrical connector still plugged in and in good shape from what I can tell
Old Apr 25, 2016 | 08:33 AM
WatsonR's Avatar
WatsonR
After it sits all night, take a reading on oil and coolant temp, they should closely match, if not, you need a new sensor. If they are matched, may need a thermostat and/or a new water pump.
Old Apr 25, 2016 | 08:37 AM
mfiveaa's Avatar
mfiveaa
Just checked the sensor readings and they are reading 77.0 ECT and 77.8 EOT
Old Apr 25, 2016 | 08:38 AM
mfiveaa's Avatar
mfiveaa
Really hoping its not the waterpump
Old Apr 25, 2016 | 08:46 AM
WatsonR's Avatar
WatsonR
that shows the sensors are good. Two choices; Pump and t-stat... start cheap. I'll say the t-stat is designed to fail open and that both oil and coolant are close together (240/245), I'd really be looking at a new pump.
Get the PID right for fan RPM and watch it. Once locked up, its basically one for one, engine RPM = fan RPM.
TRT30 on-line coupon code for Advance Auto. Do in store pick-up and save $50 on the pump.
Those temps get much higher, you'll do damage to the motor... do not mess-around with this issue.
Old Apr 25, 2016 | 09:04 AM
mfiveaa's Avatar
mfiveaa
When watching the fan RPM what should I be looking for, and as for replacement parts is there any brand I should stay away from?
Old Apr 25, 2016 | 09:09 AM
WatsonR's Avatar
WatsonR
when temps get past 217* for oil, the fan should be locked up 1:1 engine rpm - fan RPM
Old Apr 25, 2016 | 09:13 AM
mfiveaa's Avatar
mfiveaa
okay I will do a test around the block really quick and see what happens
Old Apr 25, 2016 | 09:44 AM
POS Camaro's Avatar
POS Camaro
See if you have heat from the HVAC. If there is no heat, your water pump isn't working properly. I figured out my water pump was broken because of a high engine temperature and no heat.
Old Apr 25, 2016 | 09:46 AM
mfiveaa's Avatar
mfiveaa
My heat has been out since I bought the truck but in the 3500 miles ive had it is just now overheating.
Old Apr 25, 2016 | 09:47 AM
mfiveaa's Avatar
mfiveaa
just finished driving around and I'm getting ready to download my log data
Old Apr 25, 2016 | 10:28 AM
  #28
mfiveaa's Avatar
mfiveaa
1461591409249.xls
Here is the log data I just downloaded
Old Apr 25, 2016 | 11:07 AM
  #29
mfiveaa's Avatar
mfiveaa
Originally Posted by white Buffalo
no problem,
since you are new, we need to get you up to 20 posts so you can send & receive messages. You're about 1/4 of the way there.
It would be helpful to know about your setup. So take a bunch of posts to give some additional info about your setup:
year
miles
EGR still installed or an EGR delete?
was the oil cooler ever changed?
what type of coolant?
stock injectors?
stock programming or using a tuner?
Stock head studs?
I have stock injectors and stock programming no tuner yet.
Old Apr 25, 2016 | 11:08 AM
  #30
mfiveaa's Avatar
mfiveaa
I also have stock head studs which I eventually hope to replace with aftermarket
