Bolt in 4 Link?
Old Apr 24, 2016 | 04:24 PM
GM4WALLS's Avatar
GM4WALLS
Bolt in 4 Link?
I have been searching the web, but haven't found a 4-link built for dentsides. Anyone know of any manufacturer making a bolt in 4-link for our trucks?
Old Apr 24, 2016 | 05:20 PM
HIO Silver's Avatar
HIO Silver
Don't recall any specific "kits" so it'll have to be a universal system. Consider Paul Horton's Welder Series
Old Apr 24, 2016 | 05:28 PM
GM4WALLS's Avatar
GM4WALLS
Any experience with their products?
Old Apr 24, 2016 | 06:54 PM
HIO Silver's Avatar
HIO Silver
Not personally. I've seen them installed on 50s Chevs and Ford PUs though...
Old Apr 24, 2016 | 08:33 PM
belshe92's Avatar
belshe92
check out rough stuff specialties they have universal link suspension kits and it can be ordered with the proper brackets for whatever axle you are running. just a thought
Old Apr 24, 2016 | 09:36 PM
blue04.5's Avatar
blue04.5
I've been searching for similar stuff GM4WALLS, but kind of came up empty. I did find plenty of goodies on go fast parts dot Com. Brackets that I could use and what not. They do have four link kits as well but weld on.
You could also check Chris Alstons website for parts. Again weld on I believe.
Old Apr 24, 2016 | 10:02 PM
HIO Silver's Avatar
HIO Silver
Here's a source for weld-in systems.: https://thorbros.com/catalog/4-link-kits
Old Apr 24, 2016 | 10:58 PM
belshe92's Avatar
belshe92
i have some ideas, you could in theory buy a weld in kit and make a frame mount/sadle that mounts in place of the forward leaf spring hanger then weld a piece of heavy walled square tube to that and gusset the ends up for strength then weld the link brackets to your new cross-member in the proper locations, and for the axle end make a plate out of some heavy plate that mounts on the leaf spring pad and uses u-bolts to locate one set of links and for the other set of links you could weld a second set of perches onto the axle tube farther in towards the center section to triangulate things for locating the axle then again make a plate and u-bolt it in. that should in theory give you a system that would bolt in and out in case you ever decided to go back to leafs.
i can try to draw something up if what i'm saying doesn't make sense.
longview1
6.4L Power Stroke Diesel
Nov 16, 2010 12:25 AM
BarryMc
Mississippi Chapter
Jan 11, 2009 03:40 PM
preppypyro
Oct 23, 2006 09:21 PM
SReiman
1983 - 2012 Ranger & B-Series
Jan 24, 2004 08:24 PM
Frankentruck
May 2, 2003 09:01 PM
