All done, I used the D3TZ-15702-A which is the mercury variety.
Took all of about 15 minutes once I figured out which holes to use; plastic snaps were all in the right place and it ties in to the +side of the solenoid.
Will need to add the plastic grommet that goes around the hole where the wire passes through for long term protection though
Thanks again.
Tbruz
Thanks again.
Tbruz
I've seen a few of these lights, that's the first time I've ever seen one that worked!!!!
