Front brake line routing?
Old Apr 24, 2016 | 11:28 AM
Chilly Willy in Cali's Avatar
I have a '49 F1, firewall mounted dual power master and a jag ifs. There's a few ways to run the lines on the firewall. Where are you guys running running it ?
High, low, in the middle?
Thanks, Will
Old Apr 24, 2016 | 03:22 PM
drptop70ss's Avatar
drptop70ss
I guess it depends on where you put your booster and proportioning valve.
Old Apr 24, 2016 | 04:41 PM
I like it that way. Looks like it would keep the lines a little cooler.
Old Apr 24, 2016 | 06:38 PM
Mervy49's Avatar
Mervy49
I ran the front brake line to the passenger side along the front cross member under the rad like Dave, above.
Old Apr 30, 2016 | 07:08 PM
CBeav's Avatar
CBeav
Use a large socket or pipe to make a few coils in the lines between the master and frame to allow for cab/frame movement. Placing the lines on the rear of cross members is usually a good idea - broken belts less likely to snag them, less chance of road debris damage or something squashing them from above.
Old Apr 30, 2016 | 11:09 PM
Really good tips, once I get my firewall cleaned up I'll get these in.
Thanks! Will
Jackford
Jul 14, 2022 06:09 AM
Myfreeford
Jul 30, 2014 02:07 PM
lbrauer
Jun 30, 2011 02:09 PM
Sincityz
Sep 2, 2009 07:59 PM
78fordranger
Nov 9, 2008 06:16 PM
