Sponsored by: Kumho
flexible brake line.
Old Jul 28, 2014 | 08:37 PM
Myfreeford's Avatar
Myfreeford
I am installing a Hurst line lock on my 75 f250 and would like to use flexible brake line between the proportioning valve and the solenoid. I would also like to swap out the two lines between the master cylinder and proportioning valve.
Any concerns I should have with using flexible brake line. .. other than the cost?
Old Jul 29, 2014 | 06:07 AM
JWA's Avatar
JWA
IF whatever flexible line you'd use is rated for the pressure and use there should be no huge down sides. Question though--will this be an appearance thing with fancy lines or you thinking along another line?
For some reason I'm seeing external chromed braiding inside a tricked out engine bay?
Old Jul 29, 2014 | 12:07 PM
Myfreeford's Avatar
Myfreeford
Well, not tricked out, but working on it. .
As for functionality, I like working with flexible lines rather than hard lines. Just seems easier to fit.
Old Jul 29, 2014 | 03:06 PM
Matt@Flowmaster's Avatar
Matt@Flowmaster
Former Vendor
Hurst is one of our sister companies, so I can tell you with confidence that you won't have any problems using flexible brake line with your Hurst roll control. Make sure to use the appropriate diameter line and it will not only be totally functional, it should look pretty nice as well!
Old Jul 30, 2014 | 12:10 PM
JWA's Avatar
JWA
Originally Posted by Matt@Flowmaster
Hurst is one of our sister companies,....
As awesome as Hurst was and probably still is they've yet to replace the beautiful Ms Linda Vaughn as a spokes model.
The aforementioned Ms Vaughn was also of the right diameter, fully functional and looked pretty spectacular as well!
Old Jul 30, 2014 | 02:07 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I have a local shop here that makes SS brake lines for cheap (and any other hose you can think of...they are known for their commercial hydraulic hose). I ran SS braided hose on the rear axle of my '78...all the way from the frame to the calipers. Worked great! I think I paid $40 for all of it.
Jackford
Jul 14, 2022 06:09 AM
cjben
Aug 25, 2015 04:56 PM
pace car
Sep 30, 2012 04:11 PM
cbjr61
Sep 21, 2007 05:33 PM
FLJ
Feb 18, 2006 05:42 PM
