Flathead temperature sender
Old Apr 23, 2016 | 03:08 PM
49willard's Avatar
49willard
I checked the for sale section without luck. Does anyone have a spare single contact temperature sender. They are the same many years including my 49. Please pm me if you do.
Old Apr 25, 2016 | 05:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
8A-10884 .. 6V Temperature Sending Unit-Flathead V8-Located in left (drivers) side cylinder head / Obsolete
1948/55 I-6 & V8 trucks / 1949/55 I-6 & V8 cars.
DC's 1948/56 truck catalog (2011 paper edition) shows it on page 45 for $55.00.
This may be NOS: MUSTANG SERVICE CENTER in North Hollywood CA has 1 = 818-765-9266 .. ask for Bo.
Old Apr 25, 2016 | 07:43 PM
49willard's Avatar
49willard
Bill,
Thank you for your response. I have one coming from Ross which hopefully will be good. If not I will follow up on your post.
Old May 19, 2016 | 11:00 AM
49willard's Avatar
49willard
Problem on temp sensor resolved
As a follow up in case someone else has a similar condition.
Ross sent me a spare single post sender, thank you Ross. Unfortunately it was defective. I found another used sender which was good.
What was happening is that my original sender which came from Willard with a previous engine, a 56 nailhead Buick, tested fine however it would sometimes indicate a temperature excusion past where my test said the 212 degree point was. I have always stayed with stock gages. Willard is now powered by a 383 stroked sbc. I had the sensor installed in the intake manifold in a port right next to the thermostat. I decided to move it lower into a port in the head, same result. I started carrying an infared temp gun and could not find those kind of conditions with the gun. The current sensor indicates as it should with no overheat temperature indications. I am convinced that I never had a cooling problem but an instrument problem. It is curious that the sensor tested well but performance under operating conditions was at best sporatic. I always believe my insturments however it this case it was an instrument problem.
Old May 19, 2016 | 11:22 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I assume you are 12v? What kind of converter/Runtz/whatever are you using?
On my DD, the oil pressure sender/switch started leaking and I replaced it with a new OEM ($$) unit. My indicated OP dropped 1/2 Bar (7 psi) across the board. Point being, automotive instruments just aren't real high quality, certified instruments. Best for indicating trends. I can understand your concern tho, you can tell yourself, "It's not really that hot" but psychologically you'll always be wondering.
Old May 19, 2016 | 12:52 PM
Mixer man's Avatar
Mixer man
True dat. I consider their readings nominal.
Old May 19, 2016 | 02:09 PM
49willard's Avatar
49willard
Ross,
I have individual dropping resistors that I installed on the 3 gauges shortly after I bought Willard in 1977. I measured the actual current flow using a 6v power supply and then purchased dropping resisters calculated to maintain the 6v for the gauges. Amazing that I still even remember!
I found in my heated pot of water test that the gauge does have good repeatability. The test gave me temperatures to go with the gauge markings.
bobchil
Modular V10 (6.8l)
13
Feb 15, 2026 03:39 AM
Jordan84
Dec 6, 2011 09:04 AM
mdeerslyr
1997 - 2003 F150
Jan 4, 2008 06:37 PM
motox411
1997 - 2003 F150
Nov 28, 2003 07:08 PM
PAUL_2
Mar 22, 2001 11:26 PM
