Sponsored by: Auxito
temp sensor
Old Jan 3, 2008 | 05:05 PM
mdeerslyr's Avatar
mdeerslyr
temp sensor
can someone tell me where my temp sensor is located? 2002 f150 5.4v8.its not located on top of intake by thermostat housing like the 99 f150
Old Jan 3, 2008 | 07:19 PM
antony25's Avatar
antony25
this vehicle uses a cylinder head temp sensor only. the pcm and the instrument cluster share the same sensor located under the intake on the driverside cyl head.
Old Jan 4, 2008 | 03:18 PM
mdeerslyr's Avatar
mdeerslyr
hey, could the thermostat be causing this? even though my truck isnt overheating and the dash guage reads normal.this is the oe thermostat, and since i have 97,000 miles on engine should i start there??
Old Jan 4, 2008 | 03:31 PM
Thomas Hutchins's Avatar
Thomas Hutchins
Causing what? What are the symptons and What type of engine, etc,
Old Jan 4, 2008 | 04:09 PM
mdeerslyr's Avatar
mdeerslyr
2002 f150 5.4 v8. reading said temp sensor telling engine to cool. which in return ,my truck is sucking fuel. cannot find where temp sensor is ,book said left side of intake. on the 99"s its right next to the thermostat housing. on my truck its not. ive been to auto parts store an they are baffled.
Old Jan 4, 2008 | 04:32 PM
KingRanchMan02's Avatar
KingRanchMan02
The temp sensor is located underneath the intake manifold. It is near the front of the engine in the cylinder head on the drivers side of the vehicle.
Good luck!
Old Jan 4, 2008 | 05:02 PM
mdeerslyr's Avatar
mdeerslyr
so in other words i should let the dealer replace it?is tear down hard?
thanks
Old Jan 4, 2008 | 06:37 PM
ncranchero's Avatar
ncranchero
See also: https://www.ford-trucks.com/forums/6...?highlight=CHT
ford coonhunter
1997 - 2003 F150
Aug 26, 2012 09:33 PM
BigBlue92
Mar 27, 2011 09:10 AM
salf100
Sep 20, 2010 11:11 AM
joebeeone
1997 - 2003 F150
May 2, 2006 09:10 PM
billybubba
1997 - 2003 F150
Jan 11, 2005 05:29 PM
