2014+ Transit 2014+ full size Ford Transit Van, Wagon, Cutaway and Chassis-Cab
Intermittent no-start
Old Dec 15, 2017 | 09:48 AM
  #46
dmustang's Avatar
dmustang
Originally Posted by Sam I Am
It has been my experience that when a fuel pump is failing, that is how it acts. It may randomly die while driving or intermittently fail to start. It may run terrific one moment then dog out. A fuel pressure test will usually tell the tale.
All fuses were checked. The old pump works the new pump worked before install. Van will start and run pouring fuel into the intake . So it's is firing and will run if it gets fuel. Some reason it's not sending power to the pump. If somebody has a reason please reply.
Old Dec 15, 2017 | 10:40 AM
  #47
Sam I Am's Avatar
Sam I Am
I don't believe it should be "pouring fuel into the intake". That sounds like a stuck open injector or fuel pressure regulator.
Old Dec 15, 2017 | 10:50 AM
  #48
Sam I Am's Avatar
Sam I Am
Looking up the fuse diagram, looks like:
there is a fuel injection pump relay at R12
and a fuel injection pump fuse at F24
in the engine compartment fuse box.
Sometimes fuses can look good and even test good with low current but not handle the load when full current is applied. And relays can wear out.
Old Dec 15, 2017 | 10:54 AM
  #49
Sam I Am's Avatar
Sam I Am
And looking up that vehicle on Rock Auto I see a fuel pump / circuit opening relay, but I do not know where on the vehicle it is located.
https://www.rockauto.com/en/catalog/...ing+relay,3380
Old Dec 15, 2017 | 02:31 PM
  #50
dmustang's Avatar
dmustang
Thanks. I ended having to tow to dealer. Still have no part to fix their recall on the driveshaft problem.
Old Dec 15, 2017 | 11:14 PM
  #51
Sam I Am's Avatar
Sam I Am
I am interested to know what the problem is.
Old Dec 16, 2017 | 07:43 AM
  #52
dmustang's Avatar
dmustang
I will post. They already replaced the battery which I didn't know is under the driver seat until I started messing with it.
Old Nov 24, 2018 | 09:55 PM
  #53
b1corr's Avatar
b1corr
I am watching this post for more info about the problem. I bought my 2015 T150 2 weeks ago and it stopped on the interstate in a construction zone. My wife was behind me and we went to a gas station bought a can and got 2 gallons of gas. Went back to the truck put the 2 gallons in and it started right up. Went up the interstate a ways and filled the tank, It only took 17 gallons so I knew that I had some kind of other problem. I drove about 10 more miles up the freeway and again the engine stopped just like it ran out of fuel. I sat for about 5 minutes and it again started. This time ran about 15 miles and failed again. I made it home after that time. Next day, after researching the problem I came up with the idea that the Fuel Pump Driver Module was the problem. I went by my Ford dealer and got the part and installed it (took about 5 minutes). Van ran great for the next day (drove about 120 miles). Day after that I drove to a customer and did some work on a conveyor line. Got ready to leave and no start. Called wife to come to my aid. I was going to tow the van home. When she arrived, I tried the van just one more time. It started so we started for home (36 miles away). The van stopped 3 times on the way home. I called the guy I bought the van from and he said they had never had any problem like that with the van. I am now thinking that maybe the inertia switch may be intermittent. I am going to jump it out tomorrow and see it that is the problem. **** I do hope you guys are still keeping up with this string. ****
MOOKIEX4
Feb 1, 2019 12:59 PM
drbmw2002
Apr 13, 2012 10:41 PM
mechelement
1983 - 2012 Ranger & B-Series
Oct 5, 2009 09:50 PM
jfulton
Jun 26, 2009 10:34 PM
00f2504door
Apr 13, 2008 08:07 PM
