Gear reduction starters
Old Apr 22, 2016 | 07:20 PM
81ChopTop's Avatar
81ChopTop
Is anybody here running a factory gear reduction starter on their truck?
Is there anything special you had to do to make it work (besides bolting it on and it working perfect)?
I just picked up a gear reduction starter for my '86 with auto trans. This was listed for a 1995 with a 351w and auto trans. When I start it, the engine will spin the starter for a second before the teeth disengage. Is this one of those times where I need to shim the starter?
The reason for going with this starter is the old style just doesn't have the power to turn over my engine when it's hot.
Old Apr 22, 2016 | 07:41 PM
FuzzFace2's Avatar
FuzzFace2
And I thought you were going to ask what is everybody using.
Not on my truck but AMC drag car RobbMc Performance Products - RobbMc Mini-Starters
Great customer service from where I have seen posted for the AMC group.
Don't know if I can help but when AMC went to the gear reduction starters the fly wheels & flex plates changed to match up right.
Think it had something to do with how deep the ring gear is from the back of the block between the 2 types.
Is there a way to see if when the gear reduction starter came out did the fly wheel & flex plates change too?
Also how do you shim a ford starter washers?
Dave ----
Old Apr 22, 2016 | 07:56 PM
81ChopTop's Avatar
81ChopTop
Different trannies, so don't know. After seeing Pioneer has wrong part numbers in their catalog, I don't think I can trust them.
Umm, pretty much:
Dorman Help! 02359 - Starter Alignment Shim | O'Reilly Auto Parts
Only $5.00, may be worth a try.
When I first seen these years ago, I just laughed. Now, I wonder.... was somebody thinking...
Old Apr 22, 2016 | 08:28 PM
kh0432's Avatar
kh0432
The permanent magnet starters need to be wired differently. You have to move the starter cable on the fender mounted solenoid to the battery side so that the battery post on the starter is hot all the time. Then run a 10 gauge wire from the empty post of the fender mounted solenoid to the switch terminal of the starter mounted solenoid. You can't just put a jumper from the battery terminal to the switch terminal on the starter, it'll stay engaged. You want to use the fender mounted solenoid to supply power to the switch terminal of the starter. It's important to keep the starter solenoid battery terminal hot all the time.
Old Apr 22, 2016 | 08:39 PM
81ChopTop's Avatar
81ChopTop
Maybe that's where I went wrong. I ran a jumper between the two terminals on the starter. That's how we always hooked up that style...but they were aftermarket ones. I'll try the other way.
Old Apr 23, 2016 | 05:06 AM
FuzzFace2's Avatar
FuzzFace2
True as that is how mine is wired in the drag car and works great.
I did not know the Ford GR starter was a permanent magnet starter.
Are all GR starters permanent magnet?
Dave ----
Old Apr 23, 2016 | 07:51 AM
Franklin2's Avatar
Franklin2
Dave ----
The ones I have messed with all seem to be permanent magnet, that is why the motor is such a small diameter.
I haven't heard of engagement problems using the jumper, but have heard of disengagement problems. When you release the key and the Ford starter relay on the fender opens, the new style starter is still spinning(but winding down) and as it's doing this is becomes a voltage generator for a short period of time. This voltage can back feed into the starter's solenoid and give the solenoid a delay, keeping it from disengaging for a moment, causing the engine to spin the starter gear more than it should.
Old Apr 23, 2016 | 10:52 AM
LARIAT 85's Avatar
LARIAT 85
The "old style" starter should turn your engine over just fine when it's hot. You have a problem somewhere if it doesn't.
How old and in what condition are your battery cables? Check the ground connection where the negative battery cable attaches to the engine block. I had a problem similar to yours once and it tuned out to be a rusty nut and washer where the ground connection to the block was. After I cleaned it up, my truck was able to fire off a hot engine with even 16 degrees of ignition timing with no problem!
Old Apr 23, 2016 | 11:08 AM
81ChopTop's Avatar
81ChopTop
That's exactly what mine is doing. It stays engaged for a second or two after the engine fires. Gotta switch those wires before I wreck something.
New cables, took a small angle grinder (air powered) and cleaned the connection on the block. Even cleaned the connections again before pulling the starter. I think the old starter was just getting weak, as it was pretty old, so I figured why not upgrade right away.
The new engine is about 10:1 compression and still fairly tight. Gotta run it and get it broken in the rest of the way.
Old Apr 23, 2016 | 04:19 PM
81ChopTop's Avatar
81ChopTop
Hooked up the battery cable to the starter and the switched wire (coming from the fender mounted relay) to the solenoid and all is good.
Old Apr 23, 2016 | 04:48 PM
FuzzFace2's Avatar
FuzzFace2
If only the valve noise was that easy to find & fix!
Dave ----
Old Apr 23, 2016 | 06:41 PM
81ChopTop's Avatar
81ChopTop
No doubt. What a thorn in my side that turned out to be.
Took the truck for a good ride today and it (and the starter) performed flawlessly.
<- That's me happy now.
82_F100_300Six
Jul 29, 2018 05:35 PM
52runner
19
Apr 15, 2016 06:45 PM
mesajoejoe
Mar 4, 2008 08:14 PM
Black96Cobra
1983 - 2012 Ranger & B-Series
Mar 14, 2006 03:40 PM
32MTXSHO
Dec 14, 2004 09:45 AM
