Slow Cranking
Old Apr 21, 2016 | 10:27 AM
JRS2's Avatar
JRS2
Slow Cranking
I seem to have a problem, determined it is not the starter, nor believe it is the battery - fully charged. Anyways I did have this with a 94 and it was a wiring issue, wonder if any other folks went thru this recently and what they might have found what the problem was ? Had a windshield replaced, I also took my gauges out and replaced, not sure if I upset something in the process .......
Old Apr 21, 2016 | 11:12 AM
88n94's Avatar
88n94
Take something metal and bridge between the two large posts on the fender mounted solenoid. Or better yet hook a remote starter switch directly on the starter. This will bypass most everything. Make sure the transmission is in neutral when you do this.
Old Apr 21, 2016 | 04:58 PM
JRS2's Avatar
JRS2
Ok, now since I have a 5 spd, one of the most important things might be the clutch switch, will it over ride this ? I do have a starter switch but don't believe it is long enough to go all the way to drivers seat. If my starter tests fine on the bench, what will this tell me - assuming it works fine doing this ?
Old Apr 21, 2016 | 05:24 PM
bashby's Avatar
bashby
Have the battery checked.
Old Apr 21, 2016 | 06:30 PM
JRS2's Avatar
JRS2
I found the problem. It was not the battery I think I ruled it out in the beginning, the truck previous to the last 2 weeks was running fine. Should I let others guess for maybe a day or so then reveal what the problem was ?
Old Apr 21, 2016 | 07:56 PM
bmxerbrett's Avatar
bmxerbrett
My guess would be degraded starter wiring or timing advanced too far.
Old Apr 21, 2016 | 11:05 PM
88n94's Avatar
88n94
Originally Posted by JRS2
Ok, now since I have a 5 spd, one of the most important things might be the clutch switch, will it over ride this ? I do have a starter switch but don't believe it is long enough to go all the way to drivers seat. ?
Yes, either method I mentioned under #2 will over ride(bypass) the clutch safety switch, just for your future reference. I'm glad you got the issue resolved.
I'm going to guess your problem was a bad wire between the fender mounted solenoid and the starter.
Old Apr 22, 2016 | 07:48 PM
JRS2's Avatar
JRS2
Ok guys the answer revealed, nobody got it.
The engine ground.
I found a wire dangling and it attached to the body above the heater box but not connected to anything. So I cleaned up an attachment point on the block actually on the EGR and clamped it for testing purposes with vise grips. Wallah. it started just like it was supposed to.
So cleaned up an attachment point and screwed it on.
This leads to another question, I would suspect there is more than one engine or trans ground to fame, is this correct ? If so where are they, besides this one mentioned ?
Old Apr 23, 2016 | 12:54 PM
'89F2urd's Avatar
'89F2urd
if that little ground made your starter turn faster/better, you have a bad ground from battery to block. that little ground is not the solution to your problem....so youre right, "nobody got it"...
the block ground that is adequate for the starter is on the passenger side by the engine mount.
Old Apr 23, 2016 | 10:15 PM
JRS2's Avatar
JRS2
Ok, then checking this in the next couple of days seems to be in order ....
Thks
Old Apr 23, 2016 | 10:36 PM
'89F2urd's Avatar
'89F2urd
I feel like I should have asked ... "wanna guess where the ground is that you are missing?"
then wait a few hours, then say where it is.
Old Apr 24, 2016 | 07:00 AM
JRS2's Avatar
JRS2
That would have been Ok, because it doesn't affect me getting the truck running. I wouldn't have said that to someone desperately trying to get their truck running ..... I suspect that I have a Weak ground if what you are saying is true on the other item and it just needed a boost or this extra help ?
Old Apr 24, 2016 | 07:59 AM
'89F2urd's Avatar
'89F2urd
If you mean that little ground giving it a boost or helping, indeed it can and likely did in your situation. The starter will fry little grounds though, in an event that the big one is missing or is so bad that it barely functions anymore as it should.
Old Apr 26, 2016 | 08:55 PM
JRS2's Avatar
JRS2
You were right on with your response. Turns out insulation was missing about one inch and it finally rotted out. I have had wandering idle and a check engine light lately, hopefully this will take care of that too ....
Old Apr 27, 2016 | 06:22 AM
'89F2urd's Avatar
'89F2urd
Start by pulling codes for check engine light. If you don't have a vac leak causing your idle wander, it's prob egr related and that's what the code is. Could be a diff sensor of course, but the code will fell the tale of the check engine light.
DiscardedFrog66
Sep 25, 2019 09:28 AM
Mazellan819
Aug 29, 2009 08:28 AM
fordbozo
Jul 1, 2009 07:14 AM
tchernosky
1997 - 2003 F150
Jun 9, 2007 06:55 PM
dr.f
1983 - 2012 Ranger & B-Series
Nov 16, 2003 05:28 PM
