Starter Switch
Old Aug 29, 2009 | 01:10 AM
Mazellan819's Avatar
Mazellan819
Thumbs down Starter Switch
Ok, so I am changing out my battery cables. As I am disconnecting the positive connectors from the starter (the smaller wire) the bolt just breaks off the starter switch. I have found places that sell the starter switch but I am wondering if it is even possible for me to replace that or if I am just better off replacing the entire starter? Any words of wisdom? Oh btw:
2001 F250 7.3
My reasoning for replacing the cables is because the terminals were damaged from repeated removing and corrosion seeping under the shielding.
Thanks in advance for any help!
Maze
Old Aug 29, 2009 | 07:02 AM
just another truck's Avatar
just another truck
I didn't een know they still sold the starter relays, good find. I have not done a starter on my truck yet, so I can not help you with you answer. But if it was me, I would start pulling the old one off, if it isn't a problem, then just replace the sol, if it becomes a problem, you haven't lost anything but time. Good luck!!
Old Aug 29, 2009 | 08:28 AM
Nick 99's Avatar
Nick 99
Time to call Ed the parts guy!
