vet needs help
Old Apr 20, 2016 | 04:52 PM
BillAllen388's Avatar
BillAllen388
vet needs help
I've changed the filter, do u need to change the relay and fuel regulator before I try to take the fuel pump out. How can I besure the fuel pump is bad. 99 E150. 4.2 liter
Old Apr 20, 2016 | 08:46 PM
jimandnena's Avatar
jimandnena
Hi Bill,
the best thing to check is the fuel pressure at the fuel rail for the injectors. You can usually hear the fuel pump run for a few seconds when the ignition key is turned to run. Might have to listen at the filler cap while someone cycles the key. jim
Old Apr 24, 2016 | 03:39 PM
piratse's Avatar
piratse
Get a pressure gauge (might be able to rent on from oreillys) and attach it to the rail. It's pretty easy. Then you need to drive it under load while watching the gauge (we use a dyno at our shop, but you can just run the hose under the wipers). That will help verify. Most shops can do this and it shouldn't cost much. Better to have them verify than to waste time and money doing a pump.
KingProvince
15
Nov 9, 2016 10:02 AM
grilldemon
1983 - 2012 Ranger & B-Series
Nov 26, 2015 08:48 AM
'86_150
15
May 30, 2009 02:29 AM
Engloid
Jul 20, 2008 08:12 AM
Tom Norman
Apr 14, 2005 11:21 PM
