Fuel Pump question
Old May 24, 2009 | 02:52 PM
'86_150's Avatar
'86_150
Fuel Pump question
Hi, i have had some serious low power and blue smoke problems lately. so i opened my fuel bowl valve and turned the key to see how much fuel is coming out, it is like a little stream i thought it would show some sort of pressure not just simply flowing out of the hose. I know the fuel filter is good but is that right? also my pump is dead silent when i turn the key on even with my ear next to it. could this be my problem? thanks for any info greatly appreciated.
Old May 24, 2009 | 04:11 PM
Izzy351's Avatar
Izzy351
Sure sounds like it!! You might check out the Walbro pump -- it's a nice upgrade for less than a stocker.
EDIT: Here's a linky:
http://www.aztpi.com/product.php?productid=41
EDIT2: You might also look into putting on a fuel pressure gauge. That's my very next mod....
Old May 26, 2009 | 09:47 AM
'86_150's Avatar
'86_150
Alright thanks for the info joe i think ill go with the walbro is there any special modifications i need to do to get it to work or is it a direct bolt in?And yea i was planning on getting a fuel pressure guage but they are so flippin expensive.
Old May 26, 2009 | 10:15 AM
JEV's Avatar
JEV
It's not expensive if you get one that mounts under the hood. I have my gauge mounted next to the fuel bowl. It helped me determine that I had a bad fuel pump this winter. It only gets expensive when you get an electronic one with an isolation loop...
JEV
Old May 26, 2009 | 10:17 AM
Nick 99's Avatar
Nick 99
have you checked to see that you have power to the pump?
If not a new pump wont help.
Nick
strokersace's Avatar
strokersace
I've got a used stock pump that I'll let go cheap. It was in great working order when pulled to part out the truck.
I got my fuel pressure gauge on order last week. Hopefully it'll be here in a few days!
Old May 26, 2009 | 10:48 AM
Izzy351's Avatar
Izzy351
Yeah, I'm going with a mechanical, and will mount it out by the driver's wiper (like Brandon & Ron).
Old May 26, 2009 | 12:22 PM
Maintain's Avatar
Maintain
before you go throwing parts at it, you had better use some diagnostics on that truck.
Blue smoke = oil most of the time.... could be injector O rings or low comression.
Old May 26, 2009 | 04:08 PM
strokersace
Very true. Good catch.
Old May 26, 2009 | 08:02 PM
'86_150's Avatar
'86_150
yea i replaced the injector o rings last week and the smoke has cut down a little bit but its still there, im plannin on running a compression check at school but im so busy with my 3306 its kinda hard to get the time to get it in. im gonna check the voltage and attach a guage from school to it tomorrow so i will let you guys know whats goin on. i might have to take you up on your offer stroker. thanks for the info, you guys have yet to let me down.
Old May 27, 2009 | 12:44 PM
Maintain's Avatar
Maintain
When you replaced the O rings did you follow the instructions precisely? Did you replace the upper Wire ring and spacer style ring or just the bottom 3 O rings?
Old May 28, 2009 | 12:02 AM
'86_150's Avatar
'86_150
yes sir i did replace them per ford service manual. Unfortunately i wasnt able to bring it into the shop today and run any tests but hopefully i can soon. And its getting to the point where i have very little smoke but if i stop on a grade and floor it i can barely hit 40 mph at around 3000 RPM and its just absolutely gutless so thats really what im trying to figure out.
Old May 28, 2009 | 12:19 AM
PaysonPSD's Avatar
PaysonPSD
LINK to my Photobucket pics of Walbro install. Not detailed but instructive. Be sure to read comments as well as annotation on the pics.
EDIT: I got mine off ebay from High Flow Fuel Systems. Under 120 delivered, but that was last August.
Old May 30, 2009 | 01:29 AM
'86_150's Avatar
'86_150
Ok well i heard that the ICP can make you have low power issues, poor fuel economy and blow blue smoke. so today i unplugged it and WHOA theres my power but i still have the blue smoke so would it be safe to assume that the ICP is bad? thanks for the help
Old May 30, 2009 | 01:33 AM
PaysonPSD's Avatar
PaysonPSD
Sure sounds like that could be your problem. I have a know good ICP sensor. I could send it to you for testing. PM me if you are interested.
Edit: Did the ICP connector have oil it it?
