Truck: 1955 F100
Starter Solenoid: 3 post
Ignition System: MSD Digital 6al
I have the 1 wire chrome push button starter switch from Midfifties. I just had the whole cab painted so for this button to work do i have to sand away the paint around the hole opening? I'm 99%sure i do but i want to double check here before i sand this area to metal.
It is a 12v system wired negative ground. When i bought it the discription stated it will work with both a negative and positive ground. I might just go back to the stock 2 terminal button but i liked this burton because it was chrome.
I have heard, but not researched, that if you isolate the solenoid mount from ground and reverse the battery and starter cables on the solenoid, you can use the one-wire button.
When I converted my 50 F-3 to 12 volt neg. a few years ago, I bought a 12V starter solenoid for a 56 truck which is 12 volt neg ground like my 50 is now. Well, my one wire starter button failed to energize the solenoid. So, I put back in the 6 volt original starter solenoid and it has been starting ever since. By the way I think the starter button gets its ground from the clip or whatever holds it into the dash from behind. Maybe that helps. Patrick
