Higher pitch hum when accelerating?
Old Apr 20, 2016 | 09:38 AM
Planejet42's Avatar
Planejet42
When I accelerate, I notice a higher pitch hum. Is it a vacuum problem with the tranny? Is it normal?
Old Apr 20, 2016 | 12:22 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Tires? Wheel bearing? Drive shaft u joint? P/S pump? Do you only hear it or can you feel it in the trans hump?
Old Apr 20, 2016 | 06:09 PM
mountain dewd's Avatar
mountain dewd
Does it change with how hard you accelerate?
Old Apr 21, 2016 | 10:00 AM
Planejet42's Avatar
Planejet42
It may be the power steering pump. I notice a lower hum and some other noise when I either turn all the way to the right or all the way to the left.
I know the reservoir is a little low. Do you know what kind a power steering fluid I need?
Old Apr 21, 2016 | 10:01 AM
Planejet42's Avatar
Planejet42
Yeah, it increases in pitch until the tranny shifts.
Old Apr 21, 2016 | 10:22 AM
mountain dewd
I use type F ATF in mine.
Old Apr 21, 2016 | 10:59 AM
77&79F250's Avatar
77&79F250
It may be the power steering pump. I notice a lower hum and some other noise when I either turn all the way to the right or all the way to the left. I know the reservoir is a little low. Do you know what kind a power steering fluid I need?
Type f transmission fluid.
You really need to go a local parts store and get a cheap Chilton or Hanes Ford truck repair manual. That will get you going in the right direction as far a learning basic things and general maintenance. It also has lots of pictures and that is what I use. lol Or you can even go to the local library to look at the actual paper book before you buy it. Remember those things before the internet and Kindle?
List: Repair Manual - General - 1979 Ford F-250 | O'Reilly Auto Parts
Do It Yourself (DIY) Auto Service Repair Manuals from Haynes
Also order a bunch of free 73-79 truck parts catalogs to lean item names, make it easier come time to go to the parts store. LMC, Jeffs Bronco Graveyard (78/79 Bronco's are the same front end and lots of interior parts), Macs, Dennis Carpenter, National Parts Depot ect...
Old Aug 2, 2016 | 05:35 PM
Michael1289's Avatar
Michael1289
I'm having the same problem plus I can feel vibration in the gas peddle it starts making the noise when it builds up boost between 5-15 psi
Please help
Old Aug 2, 2016 | 05:37 PM
Michael1289
Did you ever find out what the problem was??
kegomatix
Oct 4, 2012 06:52 PM
Nathan6.8
Sep 3, 2010 10:56 PM
Bigches
1983 - 2012 Ranger & B-Series
17
Aug 30, 2009 10:35 PM
rangerte
Jul 17, 2003 11:34 PM
1966ford
Jan 2, 2001 10:42 AM
