Starting difficulty
Old Apr 18, 2016 | 06:58 PM
milesg's Avatar
milesg
Starting difficulty
When starting, rapid clicking like failing batteries. Had dealer install new Motorcraft batteries, and it's still happening. Clicks when i turn the key and then labors while turning over for 20 seconds. Sometimes it takes 2 or three times before it starts. I put in a rebuilt alternater 5 years ago. It seems like a fuel problem, but I'm guessing. Any ideas? Thanks.
milesg
Old Apr 18, 2016 | 07:47 PM
crop harvester's Avatar
crop harvester
Check voltage on batteries with accurate volt meter,if below 12.6 volts then charge,check all connections,check voltage while cranking engine & report back.
Old Apr 18, 2016 | 07:59 PM
Rikster-7700's Avatar
Rikster-7700
A fuel problem would not cause your engine to turn slowly with the starter motor. To me that would point to either weak / partially discharged batteries (determined by voltage of batteries), a bad connection (either ground or hot) in the system, or a weak starter motor. The clicking and no turn could be a failing starter solenoid not letting the starter gear engage to crank the engine.
Old Feb 8, 2018 | 04:44 PM
milesg's Avatar
milesg
I have relatively new batteries, fully charged, and a new starter. Turns over very fast, but 5-10 seconds to start, as if fuel is not available at the injectors for that amount of time. Pump? Leak in fuel line? Or? What/how to test to pin it down? Thanks
MilesG
Old Feb 8, 2018 | 10:11 PM
Karlow's Avatar
Karlow
My bet is a bad connection, check the voltage drop from the battery to the engine block and from the battery to the starter.
Old Feb 9, 2018 | 07:26 AM
Walleye Hunter's Avatar
Walleye Hunter
Perform a Cody test and peek into the top of your HPOP reservoir through the allen key plug on the top. Oil level should be within an 1" or so through that hole. The Cody test applies air pressure to your HPOP lines and tests for leaking injector O rings.
Old Feb 9, 2018 | 08:15 AM
tjc transport's Avatar
tjc transport
i ain't rite
my bet is bad battery cables, bad connections, or bad starter.
Old Feb 9, 2018 | 08:22 AM
Walleye Hunter
The OP is almost two years old. I was thinking that the battery/starter issue was resolved and that this is a new problem. He probably should have started a new thread on it.
Old Feb 9, 2018 | 08:28 AM
tjc transport
i ain't rite
ah crap! did not even look at post date, only read half of first page thinking all posts were yesterday.
Old Feb 9, 2018 | 09:20 AM
milesg's Avatar
milesg
Sorry. I should have started a new thread. The battery and starter issues have been resolved. I wiil perform the Cody test and get back to you. Thanks a lot.
MilesG
bluefeather300
Feb 14, 2018 05:11 PM
pat420swed
20
Oct 10, 2015 09:56 AM
Biscayne
Jan 29, 2013 06:55 PM
meierw1
15
Dec 12, 2012 10:28 PM
turbotruck
Jun 26, 2009 11:51 PM
