backspace?
Old Apr 17, 2016 | 05:39 PM
CaptainJack_7's Avatar
CaptainJack_7
backspace?
Im looking to put 33x12.5x15s on my truck. it has pro comp 2" leveling springs on the front and stock height in the back. I was thinking of getting some mickey thompson baja claw TTCs with american racing outlaw II rims. It says the rims have a 4" backspace will this work without causing to many issues with rubbing body, bumper, or radius arms?
Old Apr 18, 2016 | 02:06 PM
CaptainJack_7
can anyone help?
Old Apr 18, 2016 | 02:29 PM
xrsfsho's Avatar
xrsfsho
F150? Or which one? If anything you'll rub on the bumper. I have the outlaws on mine with a 4 and it doesn't rub at all with 33x12.5
Old Apr 18, 2016 | 05:43 PM
Conanski's Avatar
Conanski
Every truck is different it seems. On my '90 stock 8" wheels had 4" backspacing and 31" tires on those caused rubbing on the trailing arm and sway bar at full steering lock. I had aftermarket wheels with 3.75" backspacing that did not rub with 31's, I'd say to be safe you would want no more than 3.5" backspacing for 33's.
Old Apr 18, 2016 | 06:34 PM
Nothing Special's Avatar
Nothing Special
How wide the rims are will make a difference too. An 8" wide rim with 4" of backspacing will put the tire a full inch inside of where the same tire would be on a 10" wheel with 4" of backspacing. And the general rule of thumb is to have the rim 2" narrower than the tire (although that's not cast in stone).
LAPII
Feb 10, 2021 07:31 PM
WhiteStallion
May 3, 2019 05:11 AM
Oz 89F150
May 12, 2009 10:34 AM
LARIAT 85
Dec 27, 2006 06:18 PM
Hondovious
1978 - 1996 Big Bronco
Mar 24, 2003 01:29 AM
