using a power pack for trailer lights
Old Apr 17, 2016 | 08:29 AM
old farm truck's Avatar
old farm truck
2013 F150 ecoboost
2014 EZ-Hauler (7 pin trailer)
I have a power pack I want to use for the lights in my trailer and am looking for ideas to set this up. I need to be able to turn on both the parking lights and interior lights while the truck is parked.
I want to keep the power pack located in the bed of the pickup truck so it's accessible if the vehicle needs a boost and have it charge when the vehicle is being driven
I also want to add a switch for both sets of lights.
Thanks
Old Apr 17, 2016 | 08:43 AM
ATP Pilot's Avatar
ATP Pilot
I would make sure all trailer lights are led. A trolling motor battery in a box with a built in 7-way would be easy. You could just plug your seven way into it.
Old Apr 17, 2016 | 12:13 PM
RV_Tech's Avatar
RV_Tech
I'm not entirely clear of your goal. The booster box will always stay in the truck, but you still want to be able to boost off it from that location? Just trying to clarify how you will use the booster.
Steve
Old Apr 17, 2016 | 02:46 PM
1979 Ford's Avatar
1979 Ford
Why not fix the problem or take the pickup/trailer to someone who can fix this problem? Instead of cobbling a solution that may or may not work. To me it sounds like a recipe for disaster.
It is not a bad idea to carry a power pack. To use it for trailer lighting, not so much.
RV Tech, I think he trying to put together a solution to the lighting problem he was previously having. If you are pulling something that does not have lights and needs lights, they make magnetic lights that attach to what ever you are towing and plug into a 4 way trailer plug. Wreckers use them frequently to make whatever that are towing somewhat road legal.
Old Apr 17, 2016 | 07:38 PM
ATP Pilot's Avatar
ATP Pilot
I know we are reading minds here, but he did say while he is parked.
Old Apr 17, 2016 | 08:55 PM
1979 Ford's Avatar
1979 Ford
I was thinking marker, tail, turn and stop lights.
Old Apr 18, 2016 | 08:11 AM
old farm truck
I need to turn on the trailer's parking lights and dome lights while the truck is parked. I want to use the jump box as a battery but leave it in the bed of the pickup so it's easy to get to.
Old Apr 18, 2016 | 06:48 PM
Chuck's First Ford's Avatar
Chuck's First Ford
I have a setup.. so wife can find trailer after dark... NO Truck.
I jumper the 7 pin trailer plug.(with switch)... battery pin and tail/parking lights pin... so they run off trailer battery.
your case... buy a 7 pin connector.. connect it to your jump battery... wire tail/parking lights and Ground. then plug to trailer at 7 pin.
Old Apr 18, 2016 | 06:52 PM
RV_Tech's Avatar
RV_Tech
The trailer lights are the easy part. How about the dome light? Can't capture that at the seven pin. I would problem jury rig an additional light in the cab for that and tie it to the booster battery.
Steve
Old Apr 18, 2016 | 07:57 PM
old farm truck
Oops by dome light I meant the light inside the trailer not the cab of the truck. Rigging everything up to a 7 pin trailer plug sounds like a good plan. I also like the idea of getting a set of wrecker lights that I can stick on the back of the trailer in an emergency. Thanks all. Steven, Ryan, Chuck tried to rep you but you know how it is.
Old Apr 18, 2016 | 08:06 PM
RV_Tech's Avatar
RV_Tech
Oh, in that case it is a cake walk. Seven pin connects all the dots.
Steve
finnf250
Jun 2, 2019 05:40 AM
darylksu
Apr 12, 2019 11:59 PM
dustys7.3psd
23
Jul 21, 2009 07:49 AM
tbart16
13
Jun 9, 2007 07:36 AM
RonSeg
Jan 20, 2004 06:10 AM
