Steering Wheel Upper Plastic
Old Apr 17, 2016 | 01:22 AM
Fordication's Avatar
Fordication
I have a 93 F150 and I would like to change the rubber boot on the automatic shifter and install a new bulb for the OD indicator on the end of the shifter. I need to remove the upper plastic on the steering wheel but I cannot see how to remove with without removing the steering wheel. Can anyone tell me what I am missing? Thanks
Old Apr 17, 2016 | 02:32 AM
TexasGuy001's Avatar
TexasGuy001
There are screws in the lower half of the steering column cover. Also the ignition lock cylinder needs to be removed, although I have replaced the shift boot with out doing so, but it's difficult. To remove the lock cylinder turn it to the run position and press the pin on the bottom, which is accessed through a hole on the lower cover.
Old Apr 17, 2016 | 03:14 AM
Fordication
That is the lower plastic. I did that today and changed out the ignition lock cylinder. I need to remove the top plastic one to get to the boot and to change out the failed bulb.
Old Apr 17, 2016 | 06:27 AM
My4Fordtrucks's Avatar
My4Fordtrucks
At this point, without the lower part on, it is just sitting on there. Nothing else should be holding it on.
Old Apr 17, 2016 | 07:40 AM
ceej4801's Avatar
ceej4801
Gotta remove the lock cylinder you just installed and then pull the plastic off. May have to do some fancy stuff with the shifter? It is automatic. Manual shift is easier..
Nothing in the way. After that your good to go.
Old Apr 17, 2016 | 07:57 AM
Fastback460's Avatar
Fastback460
I changed the shift boot on mine last year. It comes off exactly like TexasGuy said.
Old Apr 17, 2016 | 11:06 AM
Fordication
Thank you guys. I am so glad to have you. I hate forcing anything plastic because it breaks so easy after 20+ years. I will do that today.
3Nails
1978 - 1996 Big Bronco
Apr 27, 2011 03:03 PM
big64
Jul 20, 2009 11:09 PM
truckalpers
1997 - 2003 F150
Nov 8, 2005 04:11 PM
chaser1602
1997 - 2003 F150
Aug 23, 2004 08:17 AM
bigpumpkin
Dec 13, 2002 04:01 PM
