steering column
Old Jul 20, 2009 | 06:23 PM
big64's Avatar
big64
steering column
i found a GOOD STEERING COLUMN OUT OF A 89 TRUCK. IT IS A TILT WHEEL AND THE IGNITION IS LOCKED,AND NO KEY.IS THERE A WAY TO REPLACE THE IGNITION WITHOUT TAKING THE WHOLE COLUMN APART.THANKS.
Old Jul 20, 2009 | 11:09 PM
donnor's Avatar
donnor
Getting switched...
Per the Ford Shop Manual here are the removal instructions:
"1. Disconnect the battery ground cable. Remove the steering column trim shrouds.
2. Tape the gap between the steering wheel hub and the cover casting. Cover the entire circumference of the casting. Also cover the adjacent seat and floor area with a suitable covering to protect the surrounding interior upholstery. Pull out the hazard flasher switch and tape it down toward the floor... to provide clearance for drilling out the lock cylinder retaining pin.
3. The tilt column lock cylinder retaining pin is located on the outside of the steering column cover casting adjacent to the hazard flasher button.
4. Tilt the steering column to the full up position and prepunch the lock cylinder retaining pin with a ***** punch. Using a 3.17mm (1/8 inch) diameter drill with a right angle drive, drill out the retaining pin, going no deeper that 12.7mm (1/2 inch).
NOTE: When drilling out the retaining pin, take care not to damage the cover cast housing or the hazard flasher switch.
5. Tilt the steering column to the full down position. Place a chisel at the base of the ignition lock cylinder cap, and, using a hammer, strike the chisel with sharp blows to break the cap away from the lock cylinder.
6. Using a 9.8mm (3.8 inch) diameter drill, drill down the middle of the ignition lock cylinder approximately 45mm (1-3/4 inch) until the lock cylinder breaks loose from the steering column cover casting. Remove the lock cylinder, and the drill shavings from the base of the cover cast housing.
7. Remove the steering wheel and pad as described earlier in this Section.
8. Remove the turn signal lever from the column and then remove the two attaching screws from the turn signal switch and one attaching screw from the key warning buzzer terminal. Lift the turn signal switch up and over the end of the steering shaft but do not disconnect it form the wiring harness.
9. Remove the four attaching screws from the cover casting and lift the casting over the end of the steering shaft allowing the turn signal switch to pass through the cover casting. The removal of the cover casting will expose the upper actuator (3E723). Remove the upper actuator.
10. Remove the drive gear, snap ring, and washer from the cover casting along with the upper actuator mentioned above. Thoroughly clean the components in an acceptable cleaning solution. Carefully inspect all components for any damage resulting from the drilling operation. If any of the components show signs of damage, they must be replaced. Clean the removed cover casting with compressed air to remove any drill shavings or foreign particles and carefully inspect it for damage. If the cover casting is damaged, replace it with a new one primed and painted to match the existing column."
I trust this will help!
dn.
ungerp
Nov 26, 2012 10:10 AM
JDPoore
Dec 26, 2004 07:14 PM
West Coast Bronco
1978 - 1996 Big Bronco
Mar 5, 2004 11:06 PM
mirrormaker
Aug 21, 2003 12:06 PM
