95 PCM?
Old Apr 15, 2016 | 07:49 PM
rla2005's Avatar
rla2005
Originally Posted by subford
Can you post the numbers off the PCM as F4TF does not tell us anything. The last 2 or three letters say what it is for.
Most 95 PCM computers were numbered F4TF-12A650-??? or F5TF-12A650-???
It would also help to know what transmission you have.
Yes I learned that the 1995 For EVTM is miss labeled for the 5.0L engine.
I also learned that the 1994 & 1995 trucks with the 5.0L engine that did not have the E4OD or the 4R70W transmission were all SD and did not have SFI, they were MFI trucks.
Sorry if I miss lead someone.
No worries Bill. I have found a lot of mis-information in my EVTMs as well. As they say, "Live and learn".
Old Apr 15, 2016 | 09:33 PM
Conanski's Avatar
Conanski
The auto overdrive transmission in a '95 truck should have been one of the electronically controlled versions and if so you will have a pile of codes for all the sensors and actuators that are now disconnected. Code will tell the story.
Old Apr 16, 2016 | 09:23 PM
CrappyPappy's Avatar
CrappyPappy
Well I have learned that the 5.0 PCM doesn't work for the 5.8 runs great, until it gets warmed up, I'm guessing that the advance isn't the same, and I believe the injector pulse isn't the same voltage. But no worries I found the correct one on eBay, should have it by next Friday
Old Apr 17, 2016 | 10:21 AM
Lead Head's Avatar
Lead Head
The "right" 5.0 PCM (as in one for a speed density 5.0) will run a 5.8 just fine.
I really don't understand why you wouldn't spend the 3 minutes to pull the codes. Your check engine light could be completely unrelated to the 5.0 PCM being in there.
Jimbo302
Jul 20, 2013 04:38 PM
lowboy250
May 13, 2010 05:58 PM
Truxx1956
Jul 10, 2008 11:13 PM
Hillcrest#9
Feb 28, 2008 02:41 PM
