Scanning 95 Powerstroke
Old May 11, 2010 | 10:32 PM
lowboy250's Avatar
lowboy250
Hello everyone,
I am trying to diagnose my 95 powerstroke 4x4 with a manual trans. It has the OBDII connector, but my mechanic buddy is unable to do a buzz test or cylinder contribution test. He was using an OTC scan tool to try to perform the tests. He's experienced so I doubt that he doesn't know what he's doing.
Is there something we're missing or do these older trucks just not have these features? I have a 1997 PCM for an auto truck, can I install that to perform the tests? Can I have my 95 PCM reflashed so that these tests can be performed?
I appreciate any help!
Old May 12, 2010 | 10:16 AM
MagKarl's Avatar
MagKarl
I believe you can get the 95 pcm reflashed. DP Tuner advertises this service for $45.
Customer Supplied PCM Flash Stock or Optional Performance Flash: DP Tuner
My OBD port works on my 95, but it could have been reflashed before I bought it.
Old May 12, 2010 | 08:54 PM
fordpride's Avatar
fordpride
check the fues for the cig. lighter if it's blow the port will be dead to.
Old May 13, 2010 | 09:18 AM
superduty4x4's Avatar
superduty4x4
If the 97 PCM isn't for a Cali rig with split shot injectors then it should work fine in your 95. I've never heard of any differences in the PCM from 95-97 that would cause you a problem. Jody at DP Tuner would know for sure.
Old May 13, 2010 | 09:46 AM
Cuda_jim's Avatar
Cuda_jim
Try scanning it with the OBD1 connector under the hood.
I have both on my 96 but it was flashed to OBD2 so the one under the dash works. Like already mentioned you may need to have yours re-flashed for OBD2 scans.
Old May 13, 2010 | 12:16 PM
RRranch's Avatar
RRranch
You can NOT use an auto computer on a 5 speed truck. the engine runs like crap and the clutch safety switch and a few other things do not work. been there tried that. Twice.
Old May 13, 2010 | 01:07 PM
superduty4x4
And I had always heard it would work... good to know.
Old May 13, 2010 | 05:58 PM
lowboy250's Avatar
lowboy250
Thanks for the help everyone. I need to get this figured out so I can see if I need injectors or not for my truck.
omar1746
Mar 15, 2016 08:43 PM
daveya48187
Escape & Escape Hybrid
Feb 5, 2013 08:11 PM
daveya48187
1983 - 2012 Ranger & B-Series
Feb 5, 2013 12:32 PM
viperrtblck
Nov 16, 2011 01:34 PM
rknight29
20
Jan 16, 2011 08:24 AM
