engine set back on a 52 f1
Old Apr 14, 2016 | 08:03 PM
dbran451's Avatar
dbran451
does any one happen to have the measurement on where your motor mounts are from the front of the frame I have a 351 w and I think I'm close thanks
Old Apr 15, 2016 | 02:09 AM
Mervy49's Avatar
Mervy49
Are you planning on power steering, headers, electric fan? I could help you with this if so. I originally installed my 351w going off measurements from the cab (driver's side cylinder head part of engine 1" clear) and found out later that this would not work when I decided on headers and power steering. I went with the toy st. box. I fabricated my motor mounts to suit the available space in the stock shock mounts and brake line to frame mount area, using factory holes in the frame.
My truck is a 49 f47, I'm pretty sure the frames are the same. Also with the electric fan I had to relocate the radiator forward.
Old Apr 15, 2016 | 02:22 PM
dbran451's Avatar
dbran451
thanks for the pictures it looks like I'm real close to where your motor is set I am running Toyota power steering headers for sure the fan is up in the air right now did you build your headers or find something that fit thanks Dave
Old Apr 15, 2016 | 02:29 PM
Mervy49's Avatar
Mervy49
They are the Sanderson's street rod version.
PIGGYONAHOG
Sep 8, 2018 05:01 PM
jerry_s
13
Dec 27, 2015 07:29 PM
Mullholland_F100
Sep 19, 2013 05:40 PM
Shane Strand
Sep 25, 2003 07:40 PM
mikejen10
Feb 15, 2002 12:12 AM
