1978 - 1996 Big Bronco
Transmission id
Old Apr 13, 2016 | 08:03 PM
jtapal's Avatar
jtapal
Transmission id
Hi all. I'm usually in the dentside forum. Doing a tranny swap on my 1979 f250. Found a 1978 bronco with a 4 speed. Reverse is back against the seat. Would this tranny be a 435 or a t-18? Thanks
Old Apr 14, 2016 | 05:33 AM
gatorfor88's Avatar
gatorfor88
That would be a np 435. A t-18 is to the right and up.
Old Apr 14, 2016 | 10:50 AM
jtapal's Avatar
jtapal
Thanks alot!
Old Apr 14, 2016 | 01:02 PM
andym's Avatar
andym
Not always true. I had an 1988 F-150 with a T-18 and reverse was to the right and down.
Best bet is to look at the case for any manufacturer markings.
Old Apr 14, 2016 | 02:19 PM
gatorfor88's Avatar
gatorfor88
Okie Dokie. After 1978 t-18's did use over and down for reverse. 1978 and earlier was over and up.
Old Apr 23, 2016 | 11:52 AM
pld2005's Avatar
pld2005
Should be a NP435.
Old Apr 29, 2016 | 03:07 PM
AbandonedBronco's Avatar
AbandonedBronco
Crawl underneath and look at it from the side.
NP435
The NP435 is known for it's smooth, round casing. It also has an aluminum shifter top:
T18
The T18 has a couple more sharp edges and straight, boxy lines on it:
Old Apr 29, 2016 | 03:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1978/79 Bronco could have either the Warner T-18 (reverse shift pattern changed circa 1973) or the New Process 435.
Warner T-18: Shift lever retainer cap threads off/on.
New Process 435: Shift lever retainer cap has two notches, is retained to the shift tower with two pins.
Snakestang96
Sep 18, 2006 10:51 AM
Icicle
Aug 26, 2005 09:16 AM
Torque Lover
Jan 19, 2005 04:53 PM
dyarumian
Sep 15, 2004 10:28 AM
debestuss
Jul 26, 2004 02:40 PM
