Clutch adjustment
Old May 2, 2009 | 01:30 PM
dspeer75's Avatar
dspeer75
Clutch adjustment
I just replaced the clutch and 3 speed transmission, the clutch engages the tranny very high off of the floor. How do I get the clutch to engage with the pedal close to the floor?
Old May 2, 2009 | 03:40 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
dspeer76
The ( " CRAYON " ) will need to be lengthen !
I think this Link that I Posted ( THREE LINKS ) in this thread, it will really ,really HELP !
Make sure you Check out all three Links in the thread !
https://www.ford-trucks.com/forums/8...-problems.html
Wally Womack
Last edited by Pro-Street/StateTK; May 2, 2009 at 03:42 PM. Reason: Watching my Ps and Qs
Old May 2, 2009 | 06:19 PM
Bgasrickshaw's Avatar
Bgasrickshaw
Originally Posted by Pro-Street/StateTK
dspeer76
Wally Womack
Lengthened. yep that sounds right
Old May 2, 2009 | 06:30 PM
dspeer75's Avatar
dspeer75
I took it for a drive and as I progressed the clutch pedal started to stick when it went all the way to the floor. It got to the point that I stopped and had to pull the pedal up. I realized I could push the clutch half way in and disengage the transmission to shift. Now what?
Old May 2, 2009 | 07:39 PM
Bgasrickshaw
Hang on...Re-thinking, it sounds like it actually needs to be shortened. If the clutch disengages/engages with the pedal too high up, that means the adjuster rod is too long.
Yep, shorten it. that sounds right. Right? Hmmm.....I always get this wrong the first time. Some kind of mental block or something.
Old May 2, 2009 | 09:35 PM
dspeer75's Avatar
dspeer75
Y'all have any idea why the clutch pedal stays on the floor when pushed all the way in? I depress it half way to shift, if I push it to the floor it won't come back up. That has become my issue as of right now, I can't figure the other issue out for this one.
Thanks for your input.
Old May 3, 2009 | 01:06 AM
Pro-Street/StateTK
dspeer75
Clutch pedal on the floor?
It would be the ( LONG Clutch Spring ) ! This spring hooks to the Clutch Arm ,and then to the front crossmember.(See if it is Still in PLACE)
Bgasrickshaw///// Makes a good point about the Clutch engaging up high, good catch Bgasrickshaw !
In the other post you said the Clutch was engaging up High if that is the Case, you need to (Turn the " CRAYON " in , and ajust it !
Heres a Link to your other (Thread )..>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
https://www.ford-trucks.com/forums/8...dal-v-2-a.html
Wally Womack
Last edited by Pro-Street/StateTK; May 3, 2009 at 01:11 AM. Reason: watching my Ps and Qs
Old May 4, 2009 | 08:59 AM
truckerstyle13's Avatar
truckerstyle13
The same thing happened to me when I just replaced my clutch, it would engage really high and if i pushed the petal down the whole way it would stick. I didn't adjust anything i just drove the truck and worked the clutch back and forth a bit and it has gone back to how it was before the new clutch. Maybe it just needs time to break in or something.
