Starter Switch Problem
Old Apr 11, 2016 | 08:19 PM
killerfrogs's Avatar
killerfrogs
89 F-150 with the 5.0, 2 wheel drive, regular cab. Just bought it a few weeks ago. I have put in a new starter, new battery (PO had a battery that was too small) new solenoid on the fender and new positive and refurbished the negative battery cable. The key cylinder will turn without the key to engage radio, but not the starter. I am fairly certain the Neutral Safety switch is bad, as it will not start at times unless I hold the shift lever up in park.
The other problem I have had is the starter sticking. It has happened twice, I removed the negative battery to stop it. I'm thinking this is not related to the neutral safety switch. Could it be related to the starter switch or the key cylinder?
Thanks for the help.
Old Apr 11, 2016 | 08:26 PM
timbersteel's Avatar
timbersteel
The starter sticking is probably due to the $8 China made part.
Spend $30 on a Motorcraft replacement and call it a day before it burns your starter up.
Old Apr 11, 2016 | 09:17 PM
88n94's Avatar
88n94
If you think the starter switch or key cylinder is causing the fender mounted solenoid to stick on, pull that little slip on wire off the fender mounted solenoid, if the starter stops then one of those was the problem.
If the starter still continues to spin, give the fender mounted solenoid a few karate chops, that will usually release a sticking solenoid and is a lot quicker than removing the battery cable. And yes replace the faulty solenoid very soon.
Old Apr 12, 2016 | 05:56 AM
tjc transport's Avatar
tjc transport
i ain't rite
sounds like your problem is a broken ignition actuator. common problem in these older trucks. it is only a $15 part, and takes about 2 hours to change.
killerfrogs
1997 - 2003 F150
Apr 11, 2016 06:29 PM
Ford in progress
Jan 1, 2012 02:05 AM
chuck25624
Oct 4, 2009 01:22 PM
rhrmusic
Apr 30, 2006 12:02 PM
bondo
Electrical Systems/Wiring
May 1, 2001 12:01 AM
