DEAR GOD HELP ME.........................
Old Mar 1, 2001 | 11:33 AM
bondo's Avatar
bondo
IN A nutshell here is my initial problem: My truck (81' F250) would not turn over. All it did was *click* click* the starter was bad so i replaced it: no help...replaced the battery,and cables,and the solenoid.. So i go and start fiddling with the ignition switch mounted below the dash on the steering column..The starter activated and is now stuck. So i had to jump out and disconnect one of the battery cables .. So i figure the starter SWITCH is bad ,got a new one and the starter is still stuck spinning . No matter where the key is in the ignition,it activates.I even disconnected all the wires to the solenoid except the battery cables,and the starter still turns when i connect the negative cable...WHAT IS GOING ON?
Old Mar 4, 2001 | 08:58 PM
cbwarrior's Avatar
cbwarrior
As for the original problem, I'm not sure, but it sounds like your solenoid is stuck now, so try smacking it with a hammer (lightly) or replacing it again, and go from there. One thing to keep in mind, now that the starter ran, you know that the wiring from the battery to the starter is good. If you hook up your old solenoid, test it by jumping from the battery terminal to the ignition terminal. If nothing happens, make sure that the solenoid has a good ground. It grounds thru the mounting bolts to the fender. You could also check the wiring from the ignition switch to the solenoid by using a test light or a volt meter, preferably the test light, because it would actually place a load on the circuit as you test it. Good luck!
88 F-150 4X4 w/5.0 EFI 5 spd
86 Ranger 2WD w/2.3L EFI 5 spd to be 351W 4bbl C4
Old Apr 26, 2001 | 11:27 AM
btc9donna's Avatar
btc9donna
>click* the starter
>is now stuck. So i
>had to jump out and
>,got a new one and
>the key is in the
>GOING ON?
hi my ford f150 wount start dont know whats roung it just died can u help me please thanks donna
Old Apr 26, 2001 | 01:26 PM
bondo's Avatar
bondo
Can't help with out more details. You can e-mail and ask a few questions, ---- llizard at bellsouth.net
Old Apr 28, 2001 | 06:10 PM
AlM's Avatar
AlM
relay must be stuck closed......have a vom to test it?
and the batty cable is on the relay's large terminal?????
Old May 1, 2001 | 12:01 AM
shumagin's Avatar
shumagin
