A/C drain issue
Old Apr 11, 2016 | 01:57 PM
03X's Avatar
03X
A/C drain issue
Hi all,
My A/C feezes up in the summer, and I think partly it is due to the fact that it is not draining.
My AC will freeze up, then if I shut the truck off and wait ten minutes or so, it will start draining heavily. But it does not drain from the drainage tube.
While the AC is running and fan is on, you can feel air blowing out of the drainage tube, so I cant see that it is blocked.
I have figured out that if I manually switch the ac on-off while driving, it will not freeze up. I have a new cycling switch installed as well.
This is not my photo, but my exact situation: It is supposed to drain from the green arrow, but after it freezes up and starts to thaw, it drains from where the red arrow is.
Here is someone else's thread, exact scenario as mine: https://www.ford-trucks.com/forums/6...n-problem.html
Any Ideas where I should start looking??
Thanks
MEGATRON2010
6.4L Power Stroke Diesel
Sep 22, 2016 06:53 PM
Ford12006
2004 - 2008 F150
May 27, 2014 10:18 AM
cgouldy
1997 - 2003 F150
May 13, 2013 05:13 AM
Spades
Nov 18, 2007 04:15 PM
jm5222
Aug 15, 2004 06:58 PM
