whats this thing?
Old Apr 4, 2016 | 11:39 PM
jrockdiddy's Avatar
jrockdiddy
whats this thing?
I was replacing headlight socket, and curious what this is... i thought fuel filter, it has fuel hose attached to it,,, but i don't think so. didn't spend much time researching either
Old Apr 5, 2016 | 07:13 AM
harley4jcs's Avatar
harley4jcs
Fuel Vapor canister I'd bet.
Old Apr 5, 2016 | 07:17 AM
Watcher58's Avatar
Watcher58
Correct
Old Apr 5, 2016 | 10:58 AM
jrockdiddy's Avatar
jrockdiddy
Do they need replaced after 16 years?
Old Apr 5, 2016 | 11:07 AM
harley4jcs's Avatar
harley4jcs
IMO ONLY if your smog inspector make you
Old Apr 5, 2016 | 12:56 PM
Apocalypse's Avatar
Apocalypse
Only thing I would replace is that air filter with a paper one
Old Apr 5, 2016 | 01:16 PM
jrockdiddy's Avatar
jrockdiddy
What kind of paper filter do you recommend? No way I'm paying $300 for k&n
Old Apr 5, 2016 | 01:25 PM
Apocalypse's Avatar
Apocalypse
OEM Motorcraft.
Old Apr 5, 2016 | 04:33 PM
harley4jcs's Avatar
harley4jcs
Champion off ebay 3 for $23.00 to the door.
Old Apr 8, 2016 | 12:21 AM
Apocalypse's Avatar
Apocalypse
No, NOT Champion off of Ebay 3 for $23.00. Get the Motorcraft FA1632 Air Filter like Ford uses for the few bucks more!!! Some things it's alright to go cheap on, like Q-tips or travel shampoo but when harley suggest going half on a lap dance that's a bit cheap, just walk away!!! Do I go to Ford when I need a new key for my truck, no they want a bajillion dollars and eBay has them for a nickle. But saving a few bucks to go with an filter with less pleats, less quality control, and not nearly a tenth the name recognition as Motorcraft you're just being a tightwad. Getting air into the engine is one of the 3 things that makes a truck run, the rest is just filler. Don't go cheap on the one thing standing in the way of getting the air clean on the way to those hungry cylinders.
$15.00 to your door, come on man
Amazon.com: Motorcraft FA1632 Air Filter: Automotive Amazon.com: Motorcraft FA1632 Air Filter: Automotive
Motorcraft warranty:
Warranty, Parts:PartsWarranty, Labor:Motorcraft offers a 12 month / 12,000 mile warranty on parts for Ford/Lincoln/ Mercury cars and light truck application. Warranty begins on date of purchase. Labor is not covered.
Champion warranty:
Manufacturer’s warranty can be requested from customer service. Click here to make a request to customer service.
Seriously Champion?!?
Our trucks require 3 things to run, fuel, spark, and oxygen. Motorcraft filter, motorcraft plugs/COP/boots, and good quality fuel. Not one person on this forum should disagree with me.
Old Apr 8, 2016 | 09:22 AM
harley4jcs's Avatar
harley4jcs
"Not one person on this forum should disagree with me."
Well I'm ONE, On several issues apparently
http://www.ebay.com/itm/350527569974?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
That's $6.25 each. Changed when needed. My X seems to be breathing JUST FINE
Jon: Did you mean to type FILTERS as to add oil in your proclamation ?? The Motorcraft 801 has been proven (to me at least) to be a totally sub-par filter HOWEVER most on the board think it's the BEST FILTER EVER. I use Mobil-1 filters SO I put my money where it REALLY matters. IMO
Old Apr 8, 2016 | 07:54 PM
Apocalypse's Avatar
Apocalypse
You know what jrock? That intake using the OEM filter housing but replacing the intake pipe is kinda neat. I might look into that! Any more pics of it?
Old Apr 8, 2016 | 09:17 PM
jrockdiddy's Avatar
jrockdiddy
Old Apr 9, 2016 | 07:38 AM
Apocalypse's Avatar
Apocalypse
I wonder if Snowseeker would fab up 3-4 of those for us 6.8 members on here... seems simple enough Thanks for the pic man! I really like the set-up!!!
If you have the extra cash and want to spruce up the engine bay a bit here is an EXTREMELY simple part to swap out that takes about 5 minutes and makes the engine compartment look 10X newer (Or as much as it can). It's well worth the money even though it seems like a frivolous purchase. It's one of the better things I have bought and I would buy it 100X over.
Amazon.com: Dorman 603-213 Coolant Reservoir: Automotive Amazon.com: Dorman 603-213 Coolant Reservoir: Automotive
Old Apr 9, 2016 | 09:29 AM
jrockdiddy's Avatar
jrockdiddy
I do need a new coolant reservoir, mines brittle and flaking...
