play in steering again
New member here. I just picked up an 01 f250 sd with 227k on it. It has*the slack in the steering that I noticed is a normal issue. I have read alot of possible solutions and just wanted some feedback. I have changed all the tie rod ends and all the ball joints along with the power steering pump and the steering damper. It looks to have a reman. Gear box on it and I have tried adjusting the box however I still have problems keeping it between the lines. I am considering the redhead or maybe a cheap used box just to see if it improves the issue before dropping a $400 redhead. Any advise on anything else to try?
Thanks guys, the wealth of knowledge here is staggering
Chris
Chris
i chased this issue on a 99 and my friends 2001 did all the same stuff as you did plus redhead box. with both out trucks u wouldn't want to have a drink cause even with out one you would be swerving.
final fix was installing a caster kits.
that helped more than all other items together.
actually mine drove fine until i replaced the ball joints with atermarket one that were probably to stiff
i think the extra caster helped over come the extra resistance in the joints
thanks
fordkid16
08-21-2010 09:30 PM
