1994 f150 steering problem
Old Aug 21, 2010 | 07:20 PM
fordkid16's Avatar
fordkid16
First this truck has new shocks,new tie rod and ends, ball joints, steering box,Pittman, and alignment and all other bushings look to be fine. There is about 1.5" of play left to right and right to left, also the front wheels don't return on their own. The alignment shop said it is caused by the ball joints not being broken in yet? Is this true or do you believe it's something else? I am out of ideas as the steering is tight except for at the steering wheel. Thanks
Old Aug 21, 2010 | 07:23 PM
Nealcrenshaw's Avatar
Nealcrenshaw
The ball joints haven't been broken in yet??? Thats a good one.
Sounds like the gear box needs adjusting.
Old Aug 21, 2010 | 08:14 PM
1992forever's Avatar
1992forever
I just put a new drag link, ball joints and pitman arm into my 1992 and there was no break in time. It worked as soon as I pulled it out of the garage. I would also suspect the gear box.
Old Aug 21, 2010 | 09:30 PM
fordkid16's Avatar
fordkid16
no play in box , once steering shaft starts to turn so does the pitman.will look at it in the morning again.
jdunbar
Sep 16, 2012 08:20 PM
64deville
15
Feb 5, 2012 04:37 PM
monckywrench
1997 - 2003 F150
Jul 23, 2011 04:35 PM
TNT
30
May 20, 2011 04:20 PM
dlash74
May 26, 2010 09:08 PM
