Code p0197
Old Apr 9, 2016 | 05:05 PM
Bigdogca1966's Avatar
Bigdogca1966
Code p0197
Ok I have a p0197 engine oil sensor low.. Anyone have this before.. Temperature is cold right now and truck was not plugged in.. Truck surges when started unless I give some steady throttle and oil warms up. Also service engine soon light comes on.. Oil change soon but been a while so hope it helps.
Old Apr 9, 2016 | 05:32 PM
Walleye Hunter's Avatar
Walleye Hunter
How is your oil level and what oil is in it? What are your local temps there?
Old Apr 9, 2016 | 06:05 PM
Bigdogca1966
Oil level good but old starting to break down ..Rotella is in it.. Nite drops into the low 30 and during the day high 50's
Old Apr 9, 2016 | 06:37 PM
Walleye Hunter
I'd start with an oil change. I do not know if you should go synthetic (5w-40) or non synthetic (15w-40) based on your temps there but that would be a start.
Old Apr 9, 2016 | 06:45 PM
Bigdogca1966
Yeah that is what I think also.. Cannot hurt anyway the old girl needs it..
Old Apr 9, 2016 | 07:20 PM
Pikachu's Avatar
Pikachu
An oil change isn't going to fix that P0197 DTC. It's a sensor code. You either have a bad sensor, or a problem in the wiring. Disconnect the sensor and run a KOEO test. If disconnecting the sensor gives you a P0198, replace the sensor. If not, the problem is in the wiring.
Old Apr 9, 2016 | 09:46 PM
Bigdogca1966
Replaced the sensor.. And still have the code p0197 so off to order the connector and cut and splice it in... Really runs good now that the sensor was replaced no hesitation at all..so off to rock auto I go...
Old Apr 9, 2016 | 10:33 PM
white Buffalo's Avatar
white Buffalo
With a scanner or multimeter you can read the voltage from the sensor and see why the PCM is seeing a voltage lower than .04 V - the range expected.
Old Apr 9, 2016 | 10:41 PM
white Buffalo
An EOT signal that is detected out of range high or low by the PCM will cause the PCM to ignore the EOT signal and default to a 212°F (100°C) value for engine oil temperature. The CHECK engine lamp will also be illuminated as long as the fault condition exists. A scanner tool will display a fixed PID value of 212°F (100°C) when EOT is in default.
So be light on the throttle on a cold engine since the PCM thinks it's hot and it's not!
Old Apr 10, 2016 | 03:39 PM
Bigdogca1966
I found the problem.. After finally looking at it with some light I saw the problem.. A dam exposed wire right at the connector.. So I just ordere a new connector should be here by Wednesday and hopefully gets rid of the p0197.. Fingers crossed
H60Driver
Sep 10, 2010 11:43 AM
claycomotrucks1991
Jun 17, 2009 07:17 AM
Trailblazed
Dec 28, 2007 04:53 PM
ponch37300
Oct 18, 2006 09:45 PM
devilsword
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 23, 2005 10:04 PM
