General Automotive Discussion
f250 SD viberation
Old Apr 9, 2016 | 04:17 AM
papasmurff67's Avatar
papasmurff67
f250 SD viberation
just bought 01 f250 sd v10 4x4 had vibration in front end turned out drive shaft was bad. replaced drive shaft and still have vibration some time. with hubs unlocked and in 2wd shaft will still turn guy i bought truck from replaced front hubs should i start checking hubs or transfer case help
Old Apr 9, 2016 | 06:25 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
on a 01 4X4 i would suspect the front axle universals. when the get old they get tight, and this will cause a front end vibration.
Old Apr 9, 2016 | 10:44 AM
MoBill122's Avatar
MoBill122
Papa Smurf
Check the outer axle seals. My 2001 had a vibration that was on & off.... scare the hell out of you going down the interstate. Was a long time before I finally realized what it was.
Old Apr 11, 2016 | 01:20 AM
papasmurff67
u joints r good even took grease will ck seals next but dont know how seals could cause it but will check tks for info
Old Apr 11, 2016 | 05:13 AM
tjc transport
i ain't rite
not front driveshaft u-joints, the ones in the front axles in the steering knuckles.
Old Apr 28, 2016 | 08:29 PM
papasmurff67
viberation
removed front drive shaft can turn transfer case yoke freely by hand but cant turn yoke on front axel with manual hubs unlocked where can i find instructions on checking the hubs to make sure they were installed correctly
LOVEMYLABXS
Nov 20, 2017 01:18 PM
Skinner F350
Sep 12, 2012 08:32 PM
Bmit
Jan 3, 2011 10:14 PM
tombob
1978 - 1996 Big Bronco
17
Jan 2, 2005 09:01 AM
cobiyero
Nov 7, 2004 06:58 PM
