Front drive shaft ujoints?
Old 11-20-2017, 11:19 AM
LOVEMYLABXS's Avatar
LOVEMYLABXS
LOVEMYLABXS is offline
LOVEMYLABXS is starting off with a positive reputation.
93 f150 all new tie rods ball joints and axle ujoints and a frontend alinment. swapped the auto hubs out for warn manuel ones. ? is I have a slight vibration the front ujoint on the driveshaft needs replacing but wonder if this can be causing the vibration? When the hubs are in FREE and tranfer case in 2 wheel does the driveshaft still turn and the bad ujoint be causing this?
Thanks
Old 11-20-2017, 01:18 PM
GoinBoarding
GoinBoarding is offline
GoinBoarding has a good reputation on FTE.GoinBoarding has a good reputation on FTE.
If the hubs are unlocked, and the transfer case is in 2x4, the front axle & front driveshaft should not rotate.
Verify the hubs & transfer case are unlocked. If they are unlocked, then your vibration is elsewhere.
Tires are the most common vibration source.
95frd
1999 to 2016 Super Duty
01-30-2008 10:27 PM
cpettymore7777
11-02-2004 11:52 PM
waynejohn
09-24-2004 08:01 PM
parks911
15
06-25-2004 05:48 PM
broncoman604
10-30-2003 09:14 AM
Quick Reply: Front drive shaft ujoints?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
