Interchangeability of 93 F-250 and 96 F-150 parts
Hello all,
I currently own a 96 strong running f150 with a 5.8 and an auto trans. I've had the truck for 8 years and it runs strong and shifts smooth. Recently the frame cracked on in in front of and behind the steering box.
I Just found a 93 f250 with a 5.8 and a 5 speed for sale for a good price and I am looking at buying it for a wood hauler/deer hauler/gravel road truck.
My question is, how interchangeable are the parts from the 96 to the 93? specifically the motor, t-case, body parts, and cab. If the trans goes on the 93 I will just sell my auto and buy another 5 speed. I know the suspension set up is different, axles are different, and the obvious of my 96 cab having an auto and the 93 has a hole for the 5 speed, but how close is everything else.
Also, are the frame dimensions the same on these two different trucks?
Thank you for taking time to read this and respond
Austin
Austin
The only difference between the two is the frame. Body, and bed swap between both. Motor, trans, and tcase will swap, but may require specific cross members. I'm not familiar with 4x4 stuff, so just guessing on the tcase. If you're keeping the F250 frame you should put the automatic in it. You'll increase your towing capacity with it. Frame dimensions should be the same as far as body mounting. Cab chassis F350's, and vans had wider frames if I recall correctly.
How hard would it be to take the electronics and externals off the 96 motor and using the 93 electronics. Just basically using the long block from the 96 in the 93.
No matter what I would want to keep the 5 speed I think. The 96 ihas the broken frame so i wouldnt have to swap trans. I just was wondering about the moror. Just incase the motor on the 93 goes, i wanted to know how hard it would be to swap the 96 5.8 long block into the 93. I didn't know what 5 speed that truck would come with and how durable they are.
The 96 can go into the 93 aslong as u have the 1-7-3 firing order. Just swap ur electronics over to the 96 engine. U might meed to swap in the lower intake from the 93 to the 96 if it doesnt have that boss on runner 5 for some iat sensor if im not mistaken.
Sell the 96 elctronics as they r hard to come by
Very difficult from an electronic perspective. On the other hand you have two complete trucks. Detailed wiring diagrams would help tremendously.
OR
Would it be worth it to swap all of my 96 stuff onto the 93 frame?
Already partially answered. But in general, autos have higher tow ratings than manuals, not because the manual trans can't handle it, but because Ford doesn't think people can let a clutch out smoothly enough to avoid other problems. When I bought an '85 F-250 new with a 351W and 3.55 gears, since I got the NP435 4 speed manual I had a GCWR of about 7,600 lbs. If I had got the C6 auto it would have had a GCWR of 10,000 lbs.
Thank you for your input
roughridn_sob
10-21-2019 05:32 AM
jempaul
08-22-2015 12:45 PM
408 Torquer
23
09-20-2014 03:45 PM
mando jake
02-26-2009 06:38 PM
