87' thru 96' frames same??
Old Nov 22, 2015 | 05:09 PM
abosely's Avatar
abosely
Are the frames the same on 87' thru 96' trucks? As far as F150 short wheelbase 4WD, frames and F250 short wheelbase frames, not referring to F250 HD or F350.
If so are the 87' - 96" F150 & F250 short SWB frames the same?
Reason I ask is I have a 92' F150 SWB that will be slowly be getting a 9" rear end, SAS, flatbed build and will be stripping down to frame, sand blasting & painting it etc...
If the frames are the same, I'll pick u a frame and build it up then when finished, swap cab onto it. My cab is in excellent condition. This way will have use of current truck till ready to swap cab.
Cheers, Allen
Old Nov 22, 2015 | 05:14 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Sometime in the obs (92-96) trucks they went with the crimple in the front end of the frame for a crash zone (my 92 F150 has it) where as the bricknose (87-91) don't have it (my 88 and brothers 91 f150 don't have it).
Trav
Old Nov 22, 2015 | 05:19 PM
abosely's Avatar
abosely
Ok I remember reading about the crumple zone, my 92' has it.
It wouldn't make a difference as far as using 92' can & front end parts on a 87'-91 would it?
Are the F150 & F250 frames the same 87' -96'?
Cheers, Allen
Old Nov 22, 2015 | 05:42 PM
Redneckfordf2502002
From what I understand it will still all bolt up the same minus the bumper will need custom mounts if I remember correctly.
All F250s don't have crumple zone if I remember correctly. Otherwise yes they are the same between F150s.
Trav
Old Nov 22, 2015 | 05:47 PM
abosely's Avatar
abosely
Ok good, I'm not wanting a F250 frame, it's just so if I find a F250 SWB frame before or cheaper than a F150 one I can use it.
The leaf springs in front aren't an issue as I'll be using coil spring front and welding in coil spring buckets anyway.
Cheers, Allen
Old Nov 22, 2015 | 08:13 PM
Diesel_Brad's Avatar
Diesel_Brad
4wd f250s are Leaf sing. All f150s are coil springs
87-91 is on frame
92-97 is another
Also, F250 never came in a short wheel base
Old Nov 22, 2015 | 08:22 PM
abosely's Avatar
abosely
Ok so it's better if I get a 92-97 frame to keep things as uncomplicated as possible.
92-97 is probably more readily available so not really an issue, but good to know what to use.
Cheers, Allen
Old Nov 22, 2015 | 09:15 PM
dixie460's Avatar
dixie460
I think only the half tons got the crunchy front end. Everything over that stayed with plain frame rails up front.
Old Nov 23, 2015 | 06:45 AM
tjc transport's Avatar
tjc transport
i ain't rite
as Brad said, if you plan on using 250 front suspension you need a 150 frame. 150 uses coil springs, and 250 uses leaf springs on the 4X4.
250 2 wheel drive had coil springs, but there was never a 250 short wheel base made.
kdwellssr
Kentucky Chapter
Feb 18, 2018 06:56 PM
Awach
Apr 8, 2016 01:46 PM
jempaul
Aug 22, 2015 12:45 PM
408 Torquer
23
Sep 20, 2014 03:45 PM
red450ih
May 24, 2002 12:58 AM
