66 F100 engine ID
Old Apr 6, 2016 | 07:43 PM
GeorgiaVol's Avatar
GeorgiaVol
66 F100 engine ID
I have a 66 F100 that has an engine I was told is not the original. I would like to list the truck for sale but want to make sure the ad is correct. Any help would be appreciated. Thanks, here are some pictures.
Old Apr 6, 2016 | 07:59 PM
85e150's Avatar
85e150
It's an FE motor painted the Ford blue that started in the '66 model year.
Beyond that, we know it's a 2bbl, non-oem air cleaner, and a little crusty.
352, 360, 390, all were equipped with 2bbl carbs, and they pretty much look the same externally. Can you see any casting codes on the manifold or cylinder heads (between the middle cylinders).
A D2TE...code would tell us it is a much later ('72 or later) motor for example.
Old Apr 6, 2016 | 08:05 PM
GeorgiaVol's Avatar
GeorgiaVol
I will look tomorrow. So this may be the original engine?
Old Apr 6, 2016 | 08:50 PM
85e150's Avatar
85e150
Possible. It would be a 352, and your casting numbers would be C6 or earlier. (C for 1960s, 5 = 1965, 4 = 1964 etc)
Old Apr 7, 2016 | 03:25 AM
jowilker's Avatar
jowilker
Agree with 85, visually it is correct for that truck. No way that any of us can tell if it is original, but it is same FE family.
John
Old Apr 7, 2016 | 09:34 AM
daveengelson's Avatar
daveengelson
Understand one way to determine is by measuring the stroke?
3.5 is the stroke for the 352 and 360 engines
3.78 is the stroke for the 390
Old Apr 7, 2016 | 11:13 AM
GeorgiaVol's Avatar
GeorgiaVol
Thanks guys, I will try to look at it tonight or this weekend. Where would the casting numbers be? Could someone show a picture please? I'm surprised there is not a serial number on it.
Old Apr 7, 2016 | 03:12 PM
daveengelson
The Fordification forum use to have a tech article listing the Casting #'s and the best guess year with the CID, not sure if still on their web-site? However; as mentioned, the casting #'s should narrow the approximate year the block was manufactured but not necessarily the CID, considering the engine is possibly 50 yrs. old and who knows whether PO had the engine rebuilt and increased the CID???
In trying to determine, perhaps a wooden dowel, or something similar, could be used by inserting in the spark plug opening, marking at the highest, then the lowest point and measure the difference??
Old Apr 7, 2016 | 03:59 PM
TA455HO's Avatar
TA455HO
Lead Gopher
If you click on this link and scroll down just past the stainless steel hub caps you can see some of the numbers that can help ID an FE engine. Typically in about the same locations, just the numbers vary as you can imagine.
https://www.ford-trucks.com/forums/1...l#post13584942
Old Apr 7, 2016 | 04:17 PM
6t6merc's Avatar
6t6merc
The valve covers and t-stat housing indicate a later motor, maybe 68-ish imo.
Eric
Old Apr 8, 2016 | 01:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Powered by Ford valve covers introduced in 1967.
352: 1958/67 Ford Passenger Cars; 1965/67 F100/350.
Old Apr 8, 2016 | 05:15 PM
GeorgiaVol's Avatar
GeorgiaVol
The intake number was d3te9425a1a which is a 73 I think.
Old Apr 8, 2016 | 06:25 PM
daveengelson
Found the Fordification Casting #'s link:
Ford FE Engine Block Casting Numbers - FORDification.com
toddelia
Jun 20, 2019 08:15 PM
paige539
Oct 3, 2014 07:21 PM
ZX2fst
Oct 27, 2010 03:27 AM
pony1966
May 26, 2010 09:22 PM
xman7896
Sep 7, 2003 04:37 PM
