front spring swap
Old Apr 5, 2016 | 10:36 PM
gneill794's Avatar
gneill794
front spring swap
Hi all,
I have a 2003 ford ex, 4x4 6L. I am in the middle of swapping out the front springs to V codes. I was able to get the passenger side done with no issues.
However, on the drivers side, the front drive shaft is in the way of the rear spring bolt. I was able to get it out with no trouble by lifting the axle.
So.... my questions are...
What is the proper way to get the spring bolt back in the same direction it came out?
Is it okay (safe) to flip the direction of the spring bolt when I put the leaf spring back in?
Thanks in advance
George
Old Apr 5, 2016 | 11:08 PM
WE3ZS's Avatar
WE3ZS
It's been a while, but I'm pretty sure I flipped the bolt to go the other way to make any future work easier.
Old Apr 5, 2016 | 11:21 PM
Watcher58's Avatar
Watcher58
Yeah you have to turn the bolt around where you can back it out without running into the shaft. My first one had every conceivable bolt turned around in the opposite direction it should have been.
Old Apr 5, 2016 | 11:22 PM
wpnaes's Avatar
wpnaes
Agree Tom, that's what I did with mine.
Funke1
Sep 14, 2015 03:50 AM
jpcnorthwood
13
Dec 5, 2010 09:16 PM
pipman76
Nov 11, 2008 03:17 AM
1970Custom
Nov 30, 2005 11:44 PM
fellro86
17
Sep 13, 2005 11:58 PM
