Have not given up
Old 04-05-2016, 08:25 PM
saauvenshine's Avatar
saauvenshine
saauvenshine is offline
Have not given up
Still trying to figure out why battery light is on and battery is draining. Have had some good ideas what to check. I went out and took the top off of voltage regulator and started truck. What I need to know is while truck is running should all three contacts (looks like points set up) be opened. All three where opened and I took my pencil and tapped on top of the battery terminal on voltage regulator. I looked in truck and battery light was off so I look at the contacts on the battery terminal on voltage regulator and they where closed. I tapped on it again and contacts opened and battery light came back on. What little time I had truck running it drained battery from 100% to 60%. How are the contacts suppose to work and any suggestions would greatly be appreciated.
Old 04-05-2016, 10:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Generators don't charge until 1000 -1500 RPM, depending on charge state of the battery. Does the light go out when you rev it?
Rick Bensco
05-14-2018 06:37 PM
cutlass
09-23-2012 11:17 PM
trucker41
12-14-2008 07:53 PM
kailor
1997-2006 Expedition & Navigator
06-19-2007 09:33 PM
93truck
1997 - 2003 F150
01-03-2005 10:38 PM
Quick Reply: Have not given up
