Torqshift-G
Old Apr 13, 2016 | 05:38 PM
  #31
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Originally Posted by troverman
I'd hate to "dilute" the Super Duty line by offering IFS on these trucks at all. I'm also pretty sure Ford would not put up with two completely different suspension designs.
OR Ford could ditch the twin i-beam and run a single commonized IFS system for 2wd and 4wd similar to what they run the F150s.
Old Apr 13, 2016 | 07:45 PM
  #32
fzrider998's Avatar
fzrider998
Originally Posted by AK_SuperDuty
Exactly. For the soccer moms who need to drive a super duty pickup, they can get better fuel economy (maybe) and have a weaker tranny on their oversize kid hauler.
Seriously? Riiight. I'm sure thats exactly why ford decided to go with a different tranny behind the gasser.
So people really can't wrap their heads around the fact that a tranny with gear ratios and capacity suited to the engine in front of it is all a very positive thing? Gotta say, I'm in awe at the lack of forward thought on this.
Old Apr 13, 2016 | 11:50 PM
  #33
texastech_diesel
Token Redneck
I agree. They're matching components instead of taking a one-size-fits-all approach.
Why not put the 6R140 into the F150 behind the EB? It's a more heavy-duty transmission right? And the 3.5EB makes more torque than the 6.2 so it probably needs something better than the grocery-getter trans the F150 has now. Probably should just put the 3.5EB in a Super Duty. More torque means it has to be better in the Class 2-3 lineup right?
Old Apr 14, 2016 | 06:28 AM
  #34
troverman's Avatar
troverman
There's a reason for everything. Yes, the EcoBoost makes more torque than the 6.2L, but gets the much lighter duty 6R80. The reason is because Ford knows the 6.2L Super Dutys may well be used for pulling and hauling nearly every day...and they must think that application would cause early failure in the 6R80. They are banking on the F-150 owners not only probably not towing and hauling daily, but also the lighter weight of that truck, combined with lighter payload and towing capacities will give a reasonable lifespan to the 6R80.
Ford has used the 6R80 since 2009 and has good experience and history with it. They know it is holding up to the EcoBoost torque, and they see it probably is also holding up to the even higher power and torque of the Navigator. I think they realize the single greatest advantage to offering the TorqShift-G transmission is the lighter weight. The 6R140 is simply a big, heavy unit.
Old Apr 14, 2016 | 07:34 AM
  #35
fordmantpw's Avatar
fordmantpw
Pretty much. Some people are just in the 'bigger HAS to be better' crowd. That's why we have the only diesel engine available in the Super Duty approaching 1000 ft-lbs of torque and not something sensible like a 4-5L with 600 ft-lbs that would do just nicely.
Old Apr 14, 2016 | 08:57 AM
  #36
LSchicago2's Avatar
LSchicago2
Very true. Half of all SD's will never tow close to 10,000 pounds, which is still F150 territory. For those people wanting a bit more towing margin than an F150, the G will be a good option. It should help the thirsty 6.2 get some MPG for fleets too.
Old Apr 14, 2016 | 09:03 AM
  #37
j palmer cass's Avatar
j palmer cass
I like soccer moms; they're neat, well groomed and clean.
A tool need only be strong enough to do the job intended. That's what we old-timers called being "work wise".
Old Apr 14, 2016 | 09:13 AM
  #38
fordmantpw's Avatar
fordmantpw
Bingo! That's right where I am. My fifth wheel is about 9500 lbs loaded. I don't feel comfortable with an F150, so I drive a Super Duty for the extra margin. I love my diesel, but I would rather have an extra 3-4 MPG instead of an extra 400 ft-lbs of torque.
Old Apr 14, 2016 | 10:36 AM
  #39
troverman's Avatar
troverman
I'm not sure I could drop down to 460lb-ft as you suggest in exchange for 3-4mpg.
But that is neither here nor there. The new transmission is happening, like it or not, and we'll be able to find out first hand soon as some of the forum members will probably buy a truck with this transmission.
Old Apr 14, 2016 | 10:53 AM
  #40
fordmantpw's Avatar
fordmantpw
Well, I meant 400 ft-lbs from the 1000 ft-lbs we will be seeing in the near future (if not on the '17). 600 ft-lbs is 50 less than my 6.4L, and that would be plenty for me.
But yes, we will find out details on the new -G tranny soon. Though I feel it will be short-lived as I'm putting money on the 10 speed coming out in the '18 model. That's why I'm waiting for a '19...well, and the hopes of an EcoBoost coming too.
Old Apr 14, 2016 | 11:15 AM
  #41
troverman's Avatar
troverman
I'd be very surprised to see the 10-speed in the HD models, except maybe the gas models. I don't believe it was built to handle nearly that much torque; maybe half that as in the Raptor or with GM's 6.2L.
Old Apr 14, 2016 | 11:43 AM
  #42
Rasalas's Avatar
Rasalas
I am not sure of the advantage of a ten speed with an engine with as wide a torque range as the PSD produces today. The more the transmission has to shift the more fuel you use and the more wear on the transmission internals. More parts to buy if it self destructs, if it can be repaired at all. Sometimes more is not necessarily better.
Old Apr 14, 2016 | 11:49 AM
  #43
LSchicago2's Avatar
LSchicago2
And those that need more can opt for a F350 or diesel.
Old Apr 14, 2016 | 11:55 AM
  #44
fordmantpw's Avatar
fordmantpw
I think the gasser will get the 10 speed while the PSD will, at a later date, get a bigger, heavier-duty 10 speed based off the smaller 10 speed.
Precisely!
I think I read that the expected MPG improvement by going to the 10 speed was around 10%. It's not just the number of gears, it's the efficiency of the tranny plus the ability to keep the engine in the most efficient part of it's power band as long as possible.
Old Apr 14, 2016 | 01:19 PM
  #45
fzrider998's Avatar
fzrider998
A little bit of searching around and maybe already covered in the earlier pages somewhere regarding the new G tranny....the "6R80" is 6 speeds; Rear-wheel drive; 800 lb. ft. capacity.
The transmission is still WELL within durability and margin for 6.2L engine.
I'm all about "more power", but I guess only to a point. Then it becomes too expensive, inefficient and just absurd. Not to compare Ram, but you can't even get the full-power diesel in their 2500 chassis, can you? I thought it was detuned.
And, an F250 still has the beef where most of us would want it...frame, axles, suspension, brake system, etc. Crawl under an F150 and an F250 and you'll QUICKLY see that the game just drastically changed.
