ford explorer 2002 HELP PLEASE!!!
Old Apr 18, 2016 | 06:37 PM
ingpag6628's Avatar
ingpag6628
The motor does spin . The teft kight on dash flashes until u turn key all the way to crank engine. Then it stops tgen it flashes rapidly the back to a steady pulse
Originally Posted by shorod
Above you mentioned the Security/Theft light is not flashing. If the key were not properly programmed, my recall is te starter would still spin the engine over but the engine will not start (fuel injectors are turned off) and the Security/Theft light would flash rapidly while trying to start the engine.
Would you confirm whether or not the starter motor is spinning the engine? In your first post you indicated that you used a hammer on the battery cables and the engine cranks but won't start. Is that still the condition you are in?
-Rod
Old Apr 18, 2016 | 09:19 PM
steve(ill)'s Avatar
steve(ill)
turn the key to the on position, but don't start... the THEFT light will come on for 3 seconds, recognize the key, then the light will go out... If it does not go out, the motor will not start...
Old May 14, 2016 | 09:03 AM
ingpag6628's Avatar
ingpag6628
Took the explorer to auto electrician shop waitung for them to diagnose it
Stevewilband
Dec 9, 2017 08:41 AM
BobL
Mar 13, 2011 09:45 PM
lonestarfordman1980
May 14, 2008 05:45 PM
prohopwer
Nov 21, 2006 08:19 PM
LOHRTBT
Feb 27, 2004 11:21 PM
