steering wheel
Old Dec 12, 2007 | 08:54 PM
dog150's Avatar
dog150
Question steering wheel
Does any body know how to straighten a steering wheel on a 92 F150 without screwing up the tierod alignment?
It's sitting about 11 o'clock. Took the wheel off hoping to just move over a cog but it has flat spot on spleen so only goes on one position.
any advice would be appreciated. thanx Dave
Old Dec 12, 2007 | 10:50 PM
88F-150pimp's Avatar
88F-150pimp
No, you'll probably have to adjust the tie rod ends, unless your steering box is really worn out, which is a definite possibility with these trucks.
Old Dec 12, 2007 | 11:09 PM
89frankenford's Avatar
89frankenford
on the old chevy's it was possible to just rotate the wheel. on yours you have to get t aligned
Old Dec 13, 2007 | 03:20 AM
TheRoadVirus's Avatar
TheRoadVirus
There you go again, franken.. preaching chevys again. Lol, jk.
Old Dec 13, 2007 | 08:25 AM
dixokai's Avatar
dixokai
I just looked under mine and there isn't any adjustment for the wheel. If I needed to center it I would have to turn the couplings on each tie rod end. mine is a 90 F250 so there may be a difference. If you do it Make sure you turn both couplings an equal amount and then check your tow angle but it shouldn't change if you turn both sides the same amount.
Old Dec 13, 2007 | 09:47 AM
phoneman91's Avatar
phoneman91
Check for loose steering before adjusting the tie rod ends. If the steering wheel has lots of play--check and see if there is play in the outer and inner tie rod ends. If there is play--replace the tie rod ends and then get an alignment and make sure that the shop aligns the steering wheel. It is surprising that a lot of shops dont see to care if the steering wheel is straight before aligning the front wheels.
Old Dec 13, 2007 | 09:52 AM
frederic's Avatar
frederic
You're right, there is no clocking adjustment between the steering wheel and the gearbox, and re-aligning the truck by lengthening one tie rod and shorting the other creates other problems such as decreasing the turning radius in one direction.
The answer is to disassemble the steering gearbox and reclock the input gear in relationship to the steering wheels rotation "off-ness". How's that for a new word?
While you have the box apart, it's a good time to clean it out, replace gaskets and seals, and so forth.
Old Dec 13, 2007 | 10:03 AM
netscaner's Avatar
netscaner
Being that his wheel sits at the 11 oclock position which is actually a minor travel of the steering box and arm, I seriously doubt steering radius problems.
I also doubt the wheel off-centering is caused by the gearbox,..........but was caused by a sloppy alignment mechanic when realigning or changing tie rod ends in the past.
As long as he turns both left and right end sleeves the same amount within a quarter to a half turn, he should not need a new alignment.
Old Dec 13, 2007 | 06:14 PM
89frankenford
Red face
hahaha nah im a ford guy BUT chevy is second place to me above everything else (except FORD!!!)
Old Dec 14, 2007 | 04:15 PM
dog150's Avatar
dog150
Thumbs up Thanks
Wow thanks guys for the responce!
