The steering wheel centering is accomplished with tie rod adjustment. To oversimplify, you lengthen one side and shorten the other by the same amount. This is presuming that the truck is _handling_ properly, that the actual toe-in / toe-out is correct. Whoever did the alignment last should have included the steering wheel centering in with the toe adjustment, since the steering wheel position affects the cancellation of the turn signals, which is a safety item.
I just did the 3" RSK on the front and my steering wheel is now about a quarter turn off too. I have to go back and make the adjustments because the turn signal issue is a royal pain with the wheel off center. My steers fine and handles right, it must have just moved the geometry when we put the lift in.
The toe in is independant of the wheel centering. the link between the two wheels is for toe.the pitman arm to rt wheel side is adj and that lengthing or shortening is used to "center" the wheel. i did my rsk and i am still tweaking a little here and theere. a yr later.its a matter of individual feel really as mine would pass with most..not me..its a fuge to the right
^^^^^ Depends on the model, perhaps. On the F250, there is no link between the two wheels; if you adjust the sleeve on the passenger-side wheel you also affect the distance between the two outer joints, thus affecting the toe. OP didn't state model....
I did the 3" rsk and then got into an accident not long after that required all new steering parts so i ended up getting the steering wheel centered by the alignment guy. But then it had pretty bad bump steer so i had to get a dropped pitman arm and ive been adjusting the steering wheel ever since.
So all I need to do is get under there and less with the sleeve on the right side? Maybe I will quit putting it off!
Truck is a f350. It does have body lift just a 3 inch I think. I do have a steering stabilizer as well but it looks like I will have to take a look under there and see if the body lift is causing the problems. I haven't owned the truck long
Also it does not pull really I just need to get the steering wheel straightened out.
Yeah, I have the drop arm but we did the job in a hurry so I haven't climbed back under to fix it. I'll get under there and tweak it over the holidays if I can.
dugyb - check to see if it has the drop arm. If not you might need to add it.
I've read there is a difference between the 250 and 350 steering arm, the 350 is slightly longer and provides a little tighter turning radius. Are there different length drop arms?
I had called one of the RSK companies to ask and they said the provide a particular part number drop arm but were not able to tell the length or if there was a length option.
