2ND GAS TANK
Old Apr 3, 2016 | 04:41 AM
MIKE138's Avatar
MIKE138
2ND GAS TANK
so I am thinking of removing my rear gas tank on my 92 f150 because i heard there is an issues where the gas will flow between them and stall the truck out. I don't use it nor do i plan on it but is it worth the work or should i just not worry about it/ 2n question shocks are they easy to replace on this truck never done it befor i bought this thing to learn how to do auto repair.
Old Apr 3, 2016 | 03:30 PM
Willz74's Avatar
Willz74
Just plug the lines to the tank
It's a pain getting to the bolts and keeping the shock from extending sometimes but bolt at the top bolt at the bottom and that's it
Old Apr 3, 2016 | 04:07 PM
Conanski's Avatar
Conanski
If it's ain't broke don't "fix" it. The fuel transfer problems can make your fuel consumption look bad and can waste gas if you don't realize it's happening and let the tank overflow, but it won't causing stalling. It's easy enough to determine if your truck has the transfer problem, if it doesn't then don't worry about but if it does then it's easy enough to work around, just drop the tank and plug both lines.
Old Apr 3, 2016 | 07:40 PM
Scndsin's Avatar
Scndsin
I've been living with cross flow for 10 years now. I never put more than 10 gallons in the front tank & drive off the full back tank first. Haven't lost any gas since the first week ownership.
Old Apr 3, 2016 | 11:12 PM
RadioControlGuy85's Avatar
RadioControlGuy85
why dont you just buy new pumps in ? there cheap on ebay.thats what i did
Old Apr 4, 2016 | 08:09 AM
Scndsin's Avatar
Scndsin
'Cause the Ford pumps are working just fine and replacements are not near the quality. So why go through a whole lot of work & cost for a few gallons of range I'm not dying for & parts of questionable reliability?
Not happening till absolutely necessary.
MarksA-C
13
Nov 27, 2011 06:38 AM
bluneon
24
Jun 22, 2006 03:40 PM
matt3763
Jan 18, 2005 07:35 PM
InboundFX4
2004 - 2008 F150
15
Mar 21, 2004 05:56 PM
Andthensometoo
1997 - 2003 F150
Sep 11, 2003 07:08 PM
