New Problem
Old Apr 3, 2016 | 07:47 PM
beliveauj's Avatar
beliveauj
Question New Problem
Just started today.When I push excelerator down my RPM'S go way up but speed doesn't keep up with the the rpm's and when it shifts it clunks.Starts and runs fine unless you excelerate.No codes are shown and has good boost.Any thoughts?
Old Apr 3, 2016 | 08:45 PM
WatsonR's Avatar
WatsonR
Check transmission fluid level.
Check your intake boots, look for cracks and loose clamps.
Old Apr 3, 2016 | 09:52 PM
BLADE35's Avatar
BLADE35
TorqShift transmission Trouble Shooting and General Info
https://www.ford-trucks.com/forums/8...eshooting.html
Old Apr 3, 2016 | 10:17 PM
Yahiko's Avatar
Yahiko
FTE Remembers
I think Benny is heading the right direction on this.
Sean <BR>
6.0L Tech Folder
Old Apr 4, 2016 | 01:13 PM
beliveauj's Avatar
beliveauj
Fluid was good and clean,boots no leaks.Weds.Ford will check it out as there are no diesel mechanics in Casa Grande,AZ.Will let you no what they find.
Old Apr 4, 2016 | 06:08 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Sounds like a transmission problem not a engine problem. As stated before check out troubleshooting link.
Old Apr 4, 2016 | 07:10 PM
beliveauj's Avatar
beliveauj
Checked the link but could not find my problem.
Old Apr 4, 2016 | 07:17 PM
bigredtruckmi
Veteran: Navy
Has tranny been serviced? Such as filter and fluid change? Might be as simple as a filter.
Old Apr 5, 2016 | 04:59 AM
Yahiko's Avatar
Yahiko
FTE Remembers
Anyone page Mark? I pestered him the other day.
If you repeat transmission 3 times and turn around in circles he should appear.
Or and don't forget the "All Hail Mark The wonderful"
Ok so I am slathering it on thicker that Tanny Fay Baker
did with her face-pairt or should I say putty. Put that stuff on with a trowel.
Sean <BR>
6.0L Tech Folder
Old Apr 5, 2016 | 09:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There's only enough information here to say something doesn't seem right.
Old Apr 5, 2016 | 10:15 PM
Yahiko's Avatar
Yahiko
FTE Remembers
Do you have anything to watch live data with? Having that can help
with diagnosing the issue. What did you use to scan for codes with?
There are some tools out there that won't show trans codes even though
they are a Pxxxx type code for the powertrain
http://www.obd-codes.com/trouble_codes/ford/
Sean <BR>
6.0L Tech Folder
Old Apr 7, 2016 | 03:18 PM
beliveauj's Avatar
beliveauj
Turbo was shot so with parts and labor $3,350.00.So what I have spent for the last three years is more than the truck is worth.HAPPY!
Old Apr 7, 2016 | 03:43 PM
250andEX's Avatar
250andEX
Good boost and the engine revving but truck not going. Bad Turbo? Troll?
Old Apr 7, 2016 | 10:59 PM
BLADE35's Avatar
BLADE35
Well it was in your first post that you had good boost
We can only go by what we're told good boost so we assume you checked boost against the book and saw good values per spec with a good gauge
Sounds like you need some gauges that would help cut cost
A 3300.00 bill is outrageous for a turbo job
IF YOU REALY NEEDED A TURBO
Should be a 1500 to 1700.00 dollar job including turbo and labor gaskets etc
It may only needed cleaned OR sensor
Sorry you got raped
All the folks that come here do it to avoid a bad deal but it takes days of research to learn the good bad ugly
Old Apr 7, 2016 | 11:07 PM
87crewdually's Avatar
87crewdually
Agreed. Something not adding up. By the OP it appears to be a Trans problem like slipping clutches or bad torque converter or pump. Not a turbo. That's the problem with forums, some people can not relay info or understand when transferred to type.
