Brake problems
Old Apr 2, 2016 | 06:14 PM
Jack Holland's Avatar
Jack Holland
Brake problems
I have a 95 f350 the brake pedal goes to the floor. I have changed the master cylinder , power brake booster and bled the brakes. The problem still exists any suggestions.
Old Apr 2, 2016 | 06:46 PM
rla2005's Avatar
rla2005
Check the adjusters on the rear brakes. Very common problem.
Old Apr 2, 2016 | 07:04 PM
My4Fordtrucks's Avatar
My4Fordtrucks
RABS pump could be bypassing. My F-150 had a spongy pedal and that was the problem.
Old Apr 2, 2016 | 07:43 PM
mblayton's Avatar
mblayton
Did you bench bleed the master cylinder? if not that is more than likely your problem Air!
Old Apr 5, 2016 | 04:31 PM
daddylee100's Avatar
daddylee100
I had a similar issue with my '92. New bench bled master, front brakes, lines, rear shoes, adjusted and bled multiple times. Did a rear disc brake swap and it fixed it for the most part. now the pedal is better but still a spongy pedal after pressure bleeding multiple times. Next is a RABS bypass..
mhbell
Sep 24, 2018 09:25 PM
timbersteel
Apr 25, 2016 11:11 PM
FordOwnerJoey
Jul 4, 2011 06:43 AM
6Fastback7
Apr 22, 2008 11:56 AM
haten'chevs
13
May 11, 2005 09:23 AM
